Question about Proview PL926WBi 19" LCD Monitor
When i turn off lcd the white screen appear
i have compaq W185q lcd monitor some times it happend that when i turn off my lcd the white screen appear ive purchased brand new lcd on july 2009 please help me to fix this problem
Posted by Kakarott goku on
2 Related Answers
skotkolr
Scott Hill
  • 558 Answers
SOURCE: flat screen monitor
I would open the monitor and look for bad capacitors on the power board
Posted on Feb 17, 2009
Anonymous
  • 225 Answers
SOURCE: Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
Posted on May 22, 2009
My Samsung Galaxy GT-S5570 is appearing a white screen.this happends after charging,and before opening the phone,,this white colour will go afer sometime.
it sounds to me like your lcd is going out.... if the phone is responsive to your touch but the screen has gone completely white and comes back, it suggests an lcd issue and you should have it replaced
Jan 05, 2014 | Samsung Galaxy GT-S5570
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Laptop screen blank all white
Either your LCD Video Cable is not plugged in snuggly or the monitor is slowly going bad. The fact that you can see the images on an external monitors says your Video Graphics Card is working fine. You'll need to disassemble the laptop to get to the cables. Get a quote from your local computer shops, then try the guys at: http://www.generalsystemsconsulting.com Most times they will fix it and ship it back by Fedex or UPS cheaper than any quote you obtained including the shipping.
Mar 15, 2012 | Compaq Presario CQ56-115DX Laptop
Padlock appears in middle of screen in an on and off way. help me get rid of it
the same thing happend to me shortly after i accidently spilled water on my monitor. Time to open it up and see if theres liquid in there. if thats not what happend to you your monitor may be going bad. check out the buttons maybe one is stuck.
Feb 22, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
Vertical lines in my laptop screen
Although it could be a screen problem, it is more likely either a loose connection on the inside of the LCD or the video inverter itself which is a board that the LCD attaches to before going to the motherboard. Try hooking it up to an external monitor and if it doesn't do it on that, then we know its not the video card / video output. After that it would be what I spoke of above.
Jun 09, 2007 | Compaq TFT500 (White) 15" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
76 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
JonSnell Electronic
JonSnell Electronic
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
