Question about Radio Communications
I7 tws bluetooth headphones and one of them wont connect but just keeps flashing red and blue and saying power on.
Posted by Carolyn Greenwell on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
Posted on Jan 03, 2008
Anonymous
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Posted on Aug 09, 2008
Anonymous
SOURCE: Bluetooth is flashing red and blue
sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
Posted on Jan 08, 2009
Anonymous
  • 67 Answers
SOURCE: Tv wont turn. Just red light keeps flashing near
I need to know the sequence of the beeps but there is a board out in it that needs to be replaced email me with the sequence and I can tell you more! cschindler at yahoo
Posted on Jul 06, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Posted on Nov 10, 2010
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
My JBl Synchros E50BT Bluetooth headphones wont charge or turn on.
sadly the battery has possibly died and will never charge .
Oct 19, 2016 | Cell Phones
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
My ooutdoor tecnology tags are not charging on my mac when I plug in I keep swicthing plug in port . Any Ideas??
How old are they and have you left them on the charger for long periods of time? The batteries are small and dont last long if they are old or constantly over charged.
Sep 09, 2013 | Outdoor Technology Ot Bluetooth Tags...
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I need to know how to sync to my iphone4
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics website)
-The Determined Observer (TheDeterObs)
Jul 13, 2010 | Plantronics Backbeat 903 Bluetooth...
How do i connect my backbeat 903 to my phone
(from plantronics web site)
Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
Radio Communications Logo
129 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
