Question about Samsung Office Equipment & Supplies
Samsung ER-290 has correct total, but randomly prints gibberish numbers across a line where an item and price should be. Now, it's also randomly printing $1.40 vs $1.50 or .40 vs .50
Posted by CCKK on
  • Patrik Parker Jul 17, 2019
    Hi CCKK , I want to help you with your question, but I need more information from you. Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
DENNIS MITCHELL
  • 1003 Answers
SOURCE: Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Posted on Jan 15, 2008
Anonymous
  • 682 Answers
SOURCE: POSSESSED 10 KEY CALCULATOR- DONT LAUGH!
your printer needs some mechnical adjustement for the print wheel and gear train by qualified service technician.
Posted on Mar 10, 2008
rwsample
Robin
  • 3 Answers
SOURCE: date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Posted on Jun 22, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Posted on Sep 26, 2009
Anonymous
SOURCE: Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Posted on Feb 06, 2010
I have a sam4s ER-5200M. Today it started printing a 4 in front of all prices on the receipt. The screen says the correct amount.
http://cashregisterguys.com/files/Samsung_5200_40M_man.pdf
i saw this on page 116,it looks relevant,,,,,,,,,21.. Display add price of linked item? When Y, the customer display shows a total of the item and linked item. For example, if PLU is $1.00 and is linked to PLU2, which is $0.25, the display will show $1.25.
it doesnt add 40 dollars so that leads me to believe that there is an error with the printer,you might need to reset and start over or call the company,good luck.
Apr 21, 2015 | Retail Supplies
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Jun 20, 2014 | Samsung SAM4s ER-650 Cash Register
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
How to change batterys in samsung er 290
you need to give it to qualified personell
Apr 12, 2013 | Sam4s Samsung Er-290 Cash Register
18 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
