Question about Ps Televison & Video
SOURCE: X-230 Xbox 360/Computer Problem.
Frist Things first!
1) CHange the input cables for Spks, for another with cooper or gold conductivity.
2) clean ends for dust on inputs.
3) try to reconnect the speakers carefully and test sound.
you can figure out when some sound are bad in any connection on this way.
Good Luck
Posted on Feb 25, 2008
SOURCE: rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal
PC pin
UPS Pin
UPS signal
RxD
TxD
TxD
RxD
GND
5
7
Ground
FG
Shield
Frame Ground
Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A
computer --------- Inside the Connector--------- UPS
DB9-F | | RJ45
pin - signal | | Pin - Color
4 DSR ->|---+ |
| | diode resistor |
6 DTR ->|---+---->|----///---o kill power | 8 Orange
1 DCD <-|----+ |
2 RxD <-|----+----------------+--o low battery| 3 Brown
7 RTS ->|----------+--///--+ |
8 RI <-|----+----------------+--o on battery | 2 Black
9 CTS <-|----+ |
| signal |
5 GND --|-----------------------o ground | 7 Red
3 TxD | |
| chassis |
Chassis/GND |-----------------------o ground | 4 Black
| Not connected | 1, 5, 6, 9, 10
Posted on Oct 24, 2008
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Posted on Dec 07, 2008
SOURCE: i nid a dog name
Camilla
Charles
Candace
Corey
Cerise
Connor
Ciganski
Posted on Nov 18, 2010
SOURCE: I have a cub cadet
Here are all of the Cub Cadet Wiring Diagrams from Cub Cadets website: http://www.cubfaq.com/wiringdiagrams.html
From your description, this almost matches the Original Cub Cadet wiring, but there are a few differences. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/original.jpg
The Cub Cadet 1200 and 1250 have the same wiring diagrams, but they are different from what you described. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/1200.jpg
I also found the Cub Cadet 125 to be somewhat similar to your description. Here it is: http://www.cubfaq.com/wiringdiagrams/125.jpg
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Apr 12, 2011
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
Jun 04, 2010 | Emerson Televison & Video
May 29, 2010 | Televison & Video
Mar 25, 2010 | Pinnacle Dazzle Video Creator Platinum...
Aug 18, 2009 | Televison & Video
Apr 21, 2009 | Dynex 20" Digital TV
Feb 27, 2009 | TruTech TT1620 DVD Recorder
Jan 10, 2009 | Ulead Videostudio 8 for PC
Apr 04, 2008 | Televison & Video
May 22, 2017 | Ps Televison & Video
14 people viewed this question
