Question about Kohler Electrical Supplies
I have a valsi 7500 watts generator 13.5 hp OHV robin engine. EH41D 1002306. i need a new caburetor for it. can you help me in this matter with a parts number for the carburetor.
Posted by Troy Gibbens on
Larry Ng
  • 5,969 Answers
Contact the maker,
ask them,
or buy one off ebay, using facts above
there is no other way. (there is a parts list at most makers web sites,Valsi
omg first google hit.
http://www.valsi.com.mx/
Posted on Sep 17, 2019
5 Related Answers
adagio1
SOURCE: Coleman 5000 watt generator Tecumseh 10 hp engine.
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Posted on Feb 01, 2010
Anonymous
SOURCE: I have a Nikota electric generator 3500 watt 6.5
I also have a NIkota 3500 generator, which had a carberator problem. I just ordered a new carb from Yilong-motor.com in China. They may be able to help you. RJL
Posted on Aug 15, 2010
NOT ME
  • 2841 Answers
SOURCE: The gas tank has rusted
Call 1-866-260-4843 http://www.valsi.com.mx/Default.aspx?lenap=1&olac=2&sedo=3 Hover over Support and then click Service Center or Distributors. You should be able to find a distributor or service center near you. One other option is to just install a fuel tank from another brand that will fit within the area that you have for the fuel tank. You can modify the mounts and secure any fuel tank that fits.
Posted on Sep 08, 2010
bonehead1967
SOURCE: I have a valsi 7500 watt 13 hp with tecumseh
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
Posted on Apr 08, 2011
George Moore
SOURCE: Can't find a carburetor for a decent generator
What is the carburetor number for a 1600 generator with a Suzuki H120A engine ??
Posted on May 27, 2011
My 7500 watt generator doesn't produce any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Jun 23, 2010 | Electrical Supplies
Tappet clearance and spark plug gap on 5.5 hp ohv engine, i have a generator which runs on natural gas made by china i just want to know the gap of tappet and the spark plug gap
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Jan 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Can I convert a Yamaha EC 5000DV generator to electric start? Where can I get those parts. rich
You can convert it BUT.... It will require spending almost as much on parts and shipping as this generator is worth.
You will need a new flywheel. Wiring harness for the start circuit, Key / switch assy, modified contgrol panel, Starter & solenoid, mounting bolts, a battery and battery holder. Additionally you will will need a voltage requlator.
Each of the parts will have to be special ordered from a Yamaha service center type shop. There is not a kit form for your unit. Depending on exactly which engine you have the 357 CC or the 410 CC you may not even be able to do it at all.
I just looked into doing the same thing for a Robin RGV 6100. "The dealers have you by the private parts!!!" The cost was about $200.00 less than buying a new generator of the equal size with an electric start system. The only thing I would not have had to buy for that conversion would be the regulator due to it being an inverter generator type unit.
Thanks for using FixYa.
Kelly
Dec 27, 2009 | Coleman Powermate 7,000 Watt 13 Hp...
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
203 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
