Remove the clamps from the suction nozzle and pull out the roller. First of all check that both ball bearings are in order, so dust and hair free and run easily without too much play. Look carefully at the different depth marks on both sides and Make sure that they are reverted to the same setting marker.The belt is in the middle and with the square gray dial in front of the suction nozzle, you fully tighten the string so that the red color face of the top is visible when you look through the hole of the suction nozzle you see that the belt is tightened and in this Position may leave the belt for a short period of time, as always as soon as possible, ensure that the tension of the belt is off after each use.In short, in the tightened position, place the suction nozzle on the mounting bell at the bottom by lifting the motor housing slightly at the front or adjusting the depth adjustment as much as possible, just what you want, first place the suction nozzle on it and fix it with the clamp and then Couterclockwise turn the gray knob into the green mode. Kirby Heritage II and Legend Vacuum Owner Video
The monitor might be faulty ....do a monitor self test ...disconnect the datat cable from the monitor and turn it on ....there would be a color code , if the color code is ... RED....GREEN....BLUE which might appear as RGB or the colors itself......then the monitor is ...if the color code is different then the monitor has to be replaced
Sounds like a panel defect. Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1000 posts to different brand TVs now. Pull up older posts there.
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
You have to look at it as if your grays were blonde, it's going to have a red hue to it as if a blonde were to dye it the same color. I suggest using a gray touch up in a darker brown tint first and then dying all of your hair a day or two later. This should prevent it from turning red and give you a color that is closer to what you're looking for.
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver.
For most users, the best method for matching colors on your screen to your printer is to print sRGB colors. The printer uses sRGB and automatically optimizes color output.
It sounds as if when the camera was dropped it impacted the image processing chip inside of the camera thus why the LCD screen appears gray in color. You may want to call Olympus and discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
