Question about Electrical Supplies
Getting generator to make electricity, Like i said my ESI 3600 was running fine, then went into a high revving, 5000 rpm, and no 110 volt output.
Posted by john barton on
Jim Hicks
    Master:
  • 661 Answers
I DON'T KNOW. HIGHER REVS SUGGEST THE LOAD
FROM THE GENERATOR WINDING IS NOT ALIVE.
PLEASE LOOK FOR A FUSE / CIRCUIT BREAKER OR MECHANICAL CONNECTION THAT CAUSED THIS DISCONNECT.
Posted on Sep 03, 2019
5 Related Answers
Anonymous
  • 585 Answers
SOURCE: Coleman Powermate 5000 reset problem
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
Posted on Dec 17, 2008
Anonymous
  • 3 Answers
SOURCE: coleman 5000 generater-no AC output
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Posted on Feb 07, 2009
Phil Rivera
  • 83 Answers
SOURCE: Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Posted on Mar 30, 2009
kirtec auto
  • 1348 Answers
SOURCE: 1993 Mazda Mx3 Revving high/Fluctuating during idle.
there is either a vacuum leak,or a valve on the throttle body called an iac that is bad. it is the idle air controller.alot of mazda have that problem
Posted on Oct 23, 2009
Ken Jackson
SOURCE: wiring diagram for electric motor
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Posted on Apr 16, 2010
Generator unregulated
Wow, I am surprised it can output that kind of power... Does the vehicle run fine otherwise beside this issue? Never heard of a vehicle alternator putting out that high of volts.
May 13, 2013 | 1996 Plymouth Grand Voyager
Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Make certain the voltage switch is set to 120 volts, not 230 volts.
If you lost your user manual, you can download on in the link below. Just click on the "open as PDF" button and it will download t your computer. http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/electric_generator.html?p=16
Dec 20, 2017 | Electrical Supplies
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
I HAVE A POWERMATE 5000 THAT SHUTS DOWN UNDER LARGE LOAD . I THINK I NEED AN IDLE CONTROL MODULE.THERE IS A 2 WIRE MODULE IN THE START CKT. #21009XA IS THIS IT AND WHERE DO I GET ONE .
Idle control comes into play when there is no power draw forcing the engine to idle with an electro magent. If you feel that the electro magnet is interfering with governor, temp remove the wire to the solenoid. Usually the idle control will not effect how the engine /gen output power. An overloaded condition will cause the engine the go the full throttle as the internal governor of the engine will try to maintain 3600 rpm. Overloaded condition will greatly shorten the life of the generator/engine. Try to use only about 80 % of rated power. Large motors can draw three times running amps. A compressor using 12 to 18 amps to run can draw over 40 amps to start.
If your generator could handle the load in the past, check the engine for loss of power, or the generator for faulty voltage regulator or capacitors out of range. Easy to check. Connect digital volt meter to plug /load and look at volt reading while running with no load and loaded. Voltage should stay between 110 to 120 under load and with no load (unless goes into idle mode). Good luck
Sep 06, 2011 | Coleman Powermate Powermate 5000W...
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
I'm reading 130VAC on the output. Can this be
It should read 115v-120v with full load. Yes, you can slow the engine down just a little, depending on the engine, there will be a high rpm adjustment. 130v with full speed, no load, is really not too bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 26, 2009 | Coleman Powermate Powermate 5000W...
No power output from my generac 5000 power plus.
sounds like you need to "flash the field". This means you've lost you excitation voltage for the generator to produce electricity. In most cases you need to get a 9volt battery and connect it to 2 & 6 inside the generator. They are Blue & Red wires, but they are not the only blue & red ones there. The generator should be running and the battery should only be connected for about 5 seconds. This is very dangerous because of all the high voltage and democrats.
Apr 09, 2009 | Generac 100 Amp 120/240-Volt Transfer...
No charge
You'll need to test to see if you are getting voltage from the brushes. This is a live test so, using something like alligator clips or such on the metal bracket of the brushes for your volt meter is a good idea. Simply start your generator with the volt meter leads attached to the the brush holders or exposed electrical connection to the brushes and see if they are producing electricity (120vac or greater). No voltage then it's your brushes, field, or stator. If they are good check the output of the voltage regulator. If it to does not kick down any voltage above 120 then it's your problem.
Note most cheap generators do not have a voltage regulator. All generators depend on the correct engine rpm to achieve normal voltage. 3600 rpm is the correct speed on a two pole generator to produce 110 to 125vac and 60hz (normally found on gas generators). 1800 rpm is the correct speed for four pole generators (normally found on diesel generators). You may set your rpms slightly higher to ensure that it's maintained underload ie 3750 for gas. Diesels usually have very good governors and don't need to be set higher.
Mar 29, 2009 | Coleman Powermate Powermate 5000W...
Coleman 1850 sport, no/ low generator output
The engine should run at 3750 rpm at no load. If that's OK then you may need to troubleshoot the capacitor inside the end of the generator opposite the rope. Since the thing has been stored for some time you may just need to flash the field of the generator to restore the residual magnetism in the rotor. The easiest way to do this is thru the 110 outlet but it's a little dangerous. Plug an old lamp cord into the outlet, start the generator, and momentarily connect a 9 volt dry cell to the wires, then shut the generator down and see if there is 110 when you restart it.
Regards,
Carl
Feb 19, 2009 | Coleman Sport 1850 Generator
Electrical Supplies Logo
141 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
