Question about Electric Garden
How do i change an electric challenge extreme head for a 6bladed head
Challenge xtreme 2000w pressure washer manual
Hi I have a challenge extreme 2500w pressure washer. it's tree years old , hardly used. I have come to set it up, but seem to have no power or start up after switching it on. any advice would be greatful?
Jul 01, 2012 | Garden
Im after a manual for challenge extreme scs718a electric chain saw
https://www.google.com/search?q=scs718a+manual&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Jan 13, 2012 | Garden
What thread is on a older toro gas straight shaft? it doesn't appear to be 3/8-24 LH but its close.
I like this question as it poses quite a challenge! Older Echos have the left handed threads on their crankshafts (and possibly even now)...but the shaft off the gear head would really confuse people who can't remove the head anyway if it was LH and that job in itself is a challenge also. Do you have any hardware that will thread onto it?...never seen an old Toro before! yes, 3/8 24 is a pretty standard SAE size...but certainly the Toro shaft could be close to that and some other size entirely > I hate to think in terms of metric on this.
Aug 12, 2010 | Toro& Electric String Trimmer
Looking for user manual challenge extreme GCS350N chain saw
This is the manual for a McCulloch electric. It should be similar Lou(is or ise).
http://weborder.husqvarna.com/order_static/doc/MOEN/MOEN2006/MOEN2006_V000249411.pdf
I read a few reviews seems they use quite a bit of bar oil. Make certain the cap is on tight. Good Luck
Lou(is) only to my Mother and Out-law when angry. LOL
For your safety please keep an eye on the chain tension too.
Feb 12, 2010 | Garden
We have a challenger pump that operates a waterfall connected with our pool. The motor on the pump burned out. Can the motor be replaced without changing out the whole pump?
Thank you for posting your question here on Fixya.com.
Yes, it is a rather common motor available thru any local pool store and also local electric motor repair shops, whose prices are likely a little lower. A common part number for it is USQ1152 from A.O. Smith. Depending on where you shop, it may have a different number but will otherwise fit without any trouble.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 14, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
How do i change wheel height on lawn mower
You do not change the wheel height, you change the cutter height,there should be an arm sticking up neart he rear wheel, you just push it to the side a little and push it either forward or backward.
Hope this helps
Apr 29, 2009 | Garden
Garden Logo
19 people viewed this question
Top Electric Garden Experts
Steve Oakes
Steve Oakes
dannydoesita
sgtstrat
Level 1 Expert
Are you an Electric Garden Expert? Answer questions, earn points and help others
