I was given a yardworks ele tric tiller and the first time i used it it stopped working after 5 min. Now it wont go. The person i got it from had never used it
take the old belt with you to any small engine or lawn equipment repair shop they should be able to match up a fractional horse power belt that will fit.
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
check your owners manual for the duty cycle rating. If it is75% , it can run for 45 mi. and needs to cool for 15 min. before using again. if it is 50% its 30 min. & 30 min.
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
i bought three rototillers an every one stopped working after one use an i took it to a dealer an he said it was the coil . why is your coils going bad ?now it wont start needs a new coil agiian i think you should be responsible seeing i bought three it was under warranty but i didnt get it out in time .i like it when it works but if it s gonna do this i wont buy any more of your tools my emalis dugie54 frontiernrt .net i would **** to hear from you ty bob .
