Question about Kenmore Refrigerators
Home do I replace the freezer control modgule on my kenmore side by side refrigerator
Posted by Furlen King on
5 Related Answers
Anonymous
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
douglas smith
  • 1462 Answers
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
Posted on Sep 10, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
Anonymous
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Water collects and freezes in bottom of Kenmore
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Posted on Jul 15, 2009
I have a Kenmore Coldspot Side-By-Side. My wife said her ice Cream was to hard so she turned the left freezer knob down one number. Now the whole Refrigerator quit working. The compressor is running but...
either the cold control is bad now or the ptc overload on the compressors bad you can bypass the cold control to check if the compressor starts then if so just replace this control
Aug 07, 2011 | Kenmore Side by Side Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Kenmore 26 cu ft side by side refrigerator 51673100
I think the Adaptive Defrost Control may be your problem part number 12566102 You may find it inside the fresh food compartment and behind the controls where you adjust the tempertaures. I will return with photos and links, Sea Breeze
Dec 20, 2009 | Kenmore Refrigerators
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Kenmore side by side freezer not cooling
try removing the panel in the freezer. you will see an evaporator fan . test it and the thermostat beside it it is one of the two
Apr 09, 2009 | Kenmore 53502 / 53504 Side by Side...
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
98 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
