Question about Furniture
Kelvinator wine cooler E2error fridge not cooling
Posted by Erica Freeze on
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
sanjar57
SOURCE: My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Posted on Apr 21, 2008
Anonymous
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
Anonymous
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
Anonymous
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 | Furniture
I have barely any space for a wine cooler and need a narrow fridge. Can anyone recommend a narrow cooling fridge for me - preferably something thermoelectric?
Without knowing the amount of space you have to put the cooler, it is difficult to find you one that will fit. What I did though was find a great site with a few brands of slim wine coolers. Look through and maybe they will have something for you.
http://www.winecoolerexpert.com/slim-wine-cooler-refrigerators.html
Is there such thing as an eco-friendly wine cooling system?
Peltier wine cooling system (thermoelectric coolers) are very eco-friendly - in comparison to other fridges. They do not contain cooling agents such as CFC an HCFC.
What is a thermoelectric wine cooling system?
Thermoelectric cooling is best used in small wine coolers. Small fans from inside the cooling fridge evenly dispense cool temperatures throughout the interior of the unit.
Wine cooler making a tat-a-tat-tat sound
Fan is hitting ice... defrost it..
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | U-Line 15WC Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Furniture Logo
146 people viewed this question
Top Furniture Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Furniture Expert? Answer questions, earn points and help others
