Question about Furniture
Ottoman came apart from leg and will not go back on. How can I fix it
Posted by Jacki Haddix on
THE LEG AND COTTER PIN CAME APART FROM THE CENTER SPROCKET
From Paul182 himself: I FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
Apr 14, 2014 | Cosco Juvenile Cosco Funsport Playard
Gaming chairs
If you are good at soldering you can pull it apart and see if you can find the right parts.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Nov 11, 2013 | Cohesion XP 11.2 Gaming Chair Ottoman with...
I want to repair my coaster bonded leather sofa ,the seat and back is peeling very very badly
Bonded leather is not very difficult to repair. Follow to directions in the following article. and you should be almost as good as new. Almost! How to Repair Bonded Leather ' EZ Fix 101.com
Aug 16, 2012 | Coaster Red Bonded Leather Sectional Sofa...
Where did the name ottoman come from?
"Ottomans" are called that because the first sultan of turkey, aman named Osman, made them popular. "Ottoman" is an englishization of the name Osman.
May 29, 2012 | Furniture
What is an ottoman?
An ottoman is a piece of furniture consisting of apadded, upholstered seat or bench, usually having neither back nor arms, oftenused as a stool, footstool or coffee table.
Can I use an ottoman as a living room table?
All ottomans are considered living room tables because oftheir use and dimensions. Therefore, anottoman is great idea for decorating your living room, if that is youraesthetic.
Should I get a living room table or a coffee table to put in front of my couch?
Living room tables are essentially the same as coffeetables, just with shorter legs. So, ifyou have a very low couch, your room would probably be best suited with aliving room table. If you have a highercouch, you can choose between a coffee and living room table.Q5: Can I usean ottoman as a living room table?
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Furniture Logo
149 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
