Question about Sharp Audio Players & Recorders
Sharp incompatable video signal has been received firestick hdmi
Posted by Kelly on
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: incompatible signal
Check your resolution settings on you playstation 3 menu's. If you are using an HDMI cable, there is a chance that your ps3 could be trying to output at 1080i or 1080p. The unit you have only goes up to 720p and if you set it any higher than that, you run the risk of having picture issues, or not getting a picture at all. Good luck to you
Posted on Apr 17, 2009
Solo3
  • 6 Answers
SOURCE: Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Posted on Jun 26, 2009
Bronson Erceg
  • 53 Answers
SOURCE: an incompatible video signal has been received
what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Posted on Oct 11, 2009
JimDe
  • 21 Answers
SOURCE: i have a sharp aquos and an older mac mini.
Actually, if your mac has the Mini Displayport connector, there is a $37 adapter you can use:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10428&cs_id=1042802&p_id=5969&seq=1&format=2
It will tie up one of your USB ports as well, which it uses for the audio signal.
Posted on Nov 04, 2009
Anonymous
  • 177 Answers
SOURCE: No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Posted on Jul 17, 2010
No sound from hdmi2 my hdmi1 is saying no signal so when I switch it to hdmi2 it gives picture but no sound is there a way to make sound come from hdmi2 im using firestick
Have you tried plugging the Firestick into HDMI 1? The Firestick has its own volume control on the remote... is that turned up? You can also press the up button (above the OK) in certain apps to increase volume. If that fails I would check sound settings in the firestick and select "passthrough", "bitstream" or "PCM" to see if it allows sound to your TV. Are you using the HDMI dongle with your Firestick? If so, you may want to plug in in without the dongle as sometimes these have issues.
When I go to hdmi4, which is where I go to access my firestick, I get a "no signal" message. How do I fix this to use my firestick?
It means there is no signal appearing at the HDMI 4 port of the TV, This could be because the Firestick is unplugged, or not working.
Repairlass1989 posted a suggestion to Additional Information that sounds good so I will repeat it in the Answer:
Repairlass1989 Nov 08, 2019 Unplug your tv and fire stick all together for 10 minutes after 10 minutes plug the tv and fire stick back in goto source hdmi channel and it should work had the same problem
I purchased a fire stick and I'm trying to hook it is to my tv I'm getting nothing should I still have my cable wire in my tv I have tried both ways and get nothin
Yes you can continue to use your cable. Firestick is connected to the HDMI port. You must have your tv source on HDMI to configure Firestick. Lastly, you must have a good wireless internet signal to setup Firestick.
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
I’m happy to assist further over the phone at https://www.6ya.com/expert/wesley_57e7f19c14a313b1
Won't accept my PS3 video signal
HDMI does not like being connected when units are powered up.
Try unplugging both units--wait and then connect the HDMI and power both units up again.
No picture
3helpful
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
2helpful
Incompatible signal
Connect ps3 with lcd via HDMI
I have no knowledge of game consoles whatsoever I suggest submitting your request to another expert as we have many here that are experts with game consoles. Sorry I couldnt help you out.
Top Sharp Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
