Question about Furniture
Cannot lower temp on wine cooler model 461 99130
Posted by joyce spada on
5 Related Answers
Demy
Demy Vasquez
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
mcnutt10
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
Rich Wright
  • 286 Answers
SOURCE: U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Posted on May 18, 2009
Anonymous
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
Jacques Alexandre
  • 183 Answers
SOURCE: Wine temp on Haier wine
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Posted on Dec 31, 2010
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
May 09, 2009 | GE PWR04FANBS Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Furniture Logo
151 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
