Question about Siemens Washing Machines
F43 error on my S14-79 Siemens washing machine ? I replaced the motor brushes but cannot clear the error?
Posted by Anthony Horgan on
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: getting error code e:02 on
model number please
Posted on Mar 28, 2008
douglas smith
  • 1462 Answers
SOURCE: My bosch washing machine wfo2865
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Posted on Aug 07, 2008
douglas smith
  • 1462 Answers
SOURCE: Where are the brushes?
easiest way is to remove the motor - just held in by simple bolts. disconnect the electrical plug and socket wiring to the motor of course.
Posted on Oct 01, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: remove siemens washing machine motor
You probably need to lever the motor back, as it is probably held in place on the motor mounts.
Posted on Dec 09, 2009
Anonymous
  • 6277 Answers
SOURCE: Hello can you please help
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 12, 2011
1helpful
2answers
I have replaced the carbon brushes in my logixx 8 machine after error code F43 appeared .the machine works ok but the washing stays soaking wet on the wash programmes
Make sure the pump wires have not got accidently dislodged when changing the brushes. Also check the program cycles, you may have accidently selected a "no spin" cycle.
Errore f43
Check motor connector block
Check motor carbon brushes
How to reset siemens washing machine?
what model of machine
F40-50 is usually something to do with the door lock interlock
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check wiring
Check tacho connections
Check motor
2helpful
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
2answers
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
2answers
My new bosch logixx front loader washing machine (3 weeks old) is showing a flashing error code F:43....what does this mean ? Thanks
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Mike
Dan Webster
Dan Webster
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
