Question about Bose Audio Players & Recorders
My bose life style 12 not getting power supply from my socket, but other appliances working from the same power socket.
Posted by hemant merchant on
Jamiu Sulaimon
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Converting a 12-hour time to 24-hour time is straight forward, though confusing. From 1:00 PM to 11:59 PM you add 12 hours, and from 12:00 AM (midnight) to12:59 AM you subtract 12 hours. Or you can simply use the following calculator toconvert to or from either system.
Posted on Jul 16, 2019
5 Related Answers
chogan
SOURCE: Bose Life style Model 5
I just went through a similar problem. Everything on the LifeStyle 5 receiver worked fine but no display. Mine is the version "2V" as shown on the serial number label on the bottom. I just replaced the C17 capacitor with a 47uF / 35V one from Radio Shack. For those of you who have been searching for a solution you've probably noticed that for the other console version you'll either have to replace the C16 or C19. For myself on the "2V" version it was the C17.
Note, I have never really done anything electrical like this before and it IS possible to do yourself (actually helps if you have a second set of hands at times).
Supplies from Radio Shack -
  1. 25W soldering iron ($8.79)
  2. Copper desolder braid ($3.99)
  3. 1/2 oz rosin core solder ($2.19)
  4. 47uF 35V capacitor ($1.19)
Here's what I did....
1. Remove the 4 screws on the back panel with a philips head screwdriver.
2. Remove the main cover (non-cd side). Use a small flathead screwdriver to push in the 3 gray tabs on the back panel and lift up so that it prys open toward the front of the unit. Take this main cover off.
3. Remove the cover on the cd side. Use that small flathead screwdriver to push in the 2 black tabs on the back panel and lift up so that it prys open toward the front of the unit. Take this cd cover off. Both top covers should now be off so you're looking at the circuit boards.
4. Remove the top circuit board. It is just held in by a few tabs. Note, I didn't disconnect any wires, ribbons, etc. I just removed the circuit board from the tabs that keep it secure and let it rest loosely on top.
5. Remove the bottom circuit board. I found this to be the trickiest step and needed an extra set of hands to hold up the top circuit board while I worked my fingers around the bottom circuit board to release it from the tabs. I also used pens (hey, at least I'm honest) as levers to keep the bottom circuit board from falling back down and getting re-secured by the tabs. Part of my problem was not recognizing there was an additional tab in the middle of the circuit board holding it down. Just be patient and keep working it. Probably took me like 10-15 minutes just to get this board removed from the tabs. Again, like the top circuit board, I didn't disconnnect any wires, ribbons, etc. I just removed the circuit board from the tabs that keep it secure.
6. Remove the C17 capacitor. Flip over the bottom circuit board and double check to make sure you're about to remove the correct capacitor. The C17 is located near the bottom left of the circuit board. (Someone else gave me the tip to make sure that when I put in the new capacitor I had the proper polarity. I'll revisit this in the next step, but at the time I was about to remove the existing C17 I just put a mark on the outside of the capacitor so I knew how it was aligned on the board. I used copper desolder braid and the soldering iron to remove the solder from the existing capacitor. I then just pulled the existing capactor out and the holes in the circuit board looked clear.
7. Install the new C17 capacitor. I noticed that the capacitors had a different color vertical band on them. Right or wrong, I used this as a guide for me to determine the polarity when installing the new one. I just put the new one in the same way as the old one (with respect to where this different colored band was and the mark I had made on the old one) and pulled the leads through the holes in the circuit board until it seemed tight enough against the circuit board. I bent the leads back (but not broken off) to hold it in place while I soldered the connection. Once I finished soldering the connection I cut off the excess from the leads with wire cutters.
8. Test the display. You don't need to re-secure the circuit boards to test it out. I believe I just flipped it over and connected the FM antenna and the AC power cords to their respective connections in the back and it worked!
9. Reassemble the console. This was much easier than the disassembly and was essentially the steps above in reverse order. Just put the bottom circuit board back in and secure it with the tabs (including the one in the center). Then do the same for the top circuit board. Put the cd cover back on until it snaps into the tabs. Do the same for the main cover. Put the 4 screws back in and you're done! Good luck!
Posted on Feb 15, 2009
Anonymous
  • 71 Answers
SOURCE: Can not get any sound to work on my bose 28 life style system first time using it. and got a new tv
If you have no sound from any source (CDs and radio included) then check the Audio Input cable at the back of the media center. Make sure it's plugged into the top portion of the 'speakers' section into where it says "main" and not "BoseLink"
If this is fully connected, but still no audio- check to make sure your Acoustimass module (subwoofer on the floor) is plugged into a working power outlet. If that fails, try unplugging both power cords for the system for about 30 seconds.
Posted on Jun 01, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Bosch Fridge Freezer (about 12 years old) has
the main board is most likely bad.
Posted on Nov 13, 2009
Anonymous
SOURCE: Bose Life styles NTSC to PAL
First, using the remote Turn the unit off.
Then, using the remote Turn the unit on.
Next, Press the [System] button
Next, Press the [Right] Arrow (once)
Next, Press the [Down] Arrow (4 times)
Next, Press the [Up] Arrow (once)
Next, Press [Enter]
Last, Press the [System] button
Done
Posted on Mar 22, 2010
Anonymous
  • 62 Answers
SOURCE: I found my ten year old pc works cambridge
1st make it sure the volts of your speaker...buy same volts power supply according to you speaker ..
example: 12v 1.0 ampere safe...
Posted on May 25, 2010
Bose Life style 12 problems with new samsung tv
Hi Candy,
On the back of your satellite box you will see a pair of Audio Out RCA jacks. One will be red, one will be white.
Simply run an RCA cable pair to the 'AUX' jacks on the rear of the BOSE.
That's it!!
Let me know if I can help you further. I will be here if you need more help, info or have a follow up comment or question.
In Case You Still Having Brother Printer Problem Then Follow Us for On: Support Services
Jan 24, 2014 | Bose Lifestyle V20 System - black Theater...
Music centre display is not functioning
The LCD back lighting has apparently gone out or the power supply to it is missing. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 29, 2013 | Bose Life Style 5 Music Center Am-fm Radio...
I have been very dissappointed with my telescope as the battery life seems to only be a few hours before it struggles to self align. Is there a gadget that will enable me to hook it up to a car battery, or...
Yes, a separate 12 vgot power pack and a cigarette lighter style power plug --
Like these:
http://www.scopestuff.com/ss_cig1.htm
and this:
http://www.harborfreight.com/12-volt-jump-start-and-power-supply-38391.html?utm_term=38391&utm_medium=cse&utm_source=nextag&hft_adv=10013
Jan 10, 2011 | Meade LX200GPS Telescope
May 31, 2009 | Bose Lifestyle 28 System
Bose Lifestyle 12 version 1
Hi, The dead display is possibly down to a capacitor problem, see fixes already covered by me, it's a 33uF capacitor either on the display board or if a newer unit on the main pcb, these cost less than $1 there is only one just change it.
The no audio may be a simple fix, do you have sound from the head set socket?, if yes then look for one of my other fixes on changing a resistor near the control socket, if no then I need to have a think... If the unit has no sound or display after changing the capacitor it could be a power supply fault. Fix the display first and let me know.
Dave
Jan 29, 2009 | Bose Lifestyle 12 System
I WANT TO CONECT MY LAP TOP TO MY LIFESTYLE 30
Go to Radio Shack and buy a cable with two phono plugs on one end and a 1/8" jack on the other end - they're pretty cheap.
Put the phono plugs into the AUX sockets on the back of the Bose, and the 1/8" jack plug into the 'headphone out' jack socket on the laptop.
Be sure that the display says you're in AUX mode. This works for me.
Good luck.
Howard.
Sep 14, 2008 | Bose Lifestyle 30 System
Lifestyle 28 System
All the manuals are available online at Bose web site
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/home_theater_system.jsp
PP
Aug 26, 2008 | Bose Lifestyle 28 System
Bose life style 48
I had the same problem and I called the Bose tech Support. They helped me with this problem, What you need to do is unplug your system and let it sit for a couple of minutes and then plu it back up and it should reset the system.
Apr 19, 2008 | Bose 3·2·1 II System
24 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
