Question about Dacor Epicure IDW30 Built-in Dishwasher
F1 error code - Dacor Epicure IDW30 Built-in Dishwasher
Posted by sherrifairy on
SAM JAYANTH CHANDRASEKAR
    President:
  • 1,197 Answers
F1 in unit implies....Inlet Valve Fault
    How to Test the Water Inlet Valve
  1. Step 1 Turnoff the power to the dishwasher. Dishwashers are direct fed straightfrom a dedicated breaker in your electrical panel. Find the breakermarked "dishwasher" and turn it off. Return to the dishwasher and tryto run it to make sure that you've got the right breaker.
  2. Step 2 Lookat the bottom front of the dishwasher; here you will see a set ofscrews holding a panel in place. Remove the screws and pull away thepanels (there may be two of them depending on your make and model). Thewater inlet valve is usually located directly in the front, on theleft-hand side. It is usually blue in color.
  3. Step 3 Remove the two screws holding the water inlet valve bracket to the dishwasher's frame.
  4. Step 4 Withthe inlet valve hanging free, pull the slide-on connector off of itsterminals. Make a note of which wire goes to which terminal, so you canhook the new one up correctly.
  5. Step 5 Setyour multimeter to read ohms (the Greek symbol for Omega) and touch oneprobe to each of the water inlet valve's terminals. If the multimeterindicates a reading of "infinity," then the valve is faulty and needsto be replaced. If you get a resistance reading, then the valve isprobably good and your problem may be elsewhere.
  6. How to Replace the Water Inlet Valve
  7. Step 1 Withthe power already off and the leads disconnected from the inlet valve,the only thing you have left to do to remove it is to disconnect thevalve from the waterlines. Before you remove any of the lines, be sureyou turn the water feed OFF. The shut-off valve is usually locatedunderneath your kitchen sink.
  8. Step 2 Place a towel underneath the water inlet valve. This will help absorb any excess water left in the hoses when you disconnect them.
  9. Step 3 Usethe adjustable wrench to loosen the fitting on the water feed hose.Once it is loosened, you can unscrew it the rest of the way by hand.
  10. Step 4 Takeyour pliers and use them to squeeze open the compression ring on therubber hose. With the compression ring open, slide it backwards, awayfrom the inlet valve, so it is no longer over the valve's nipple.
  11. Step 5 Pull the rubber hose off of the valve's nipple. If it is holding tight, try twisting it to break the seal.
  12. Step 6 Oncethe bad water inlet valve is removed, take the replacement and slidethe rubber hose over its nipple. Use the pliers to open up thecompression clamp, slide it over the hose until it is over the nippleand release.
  13. Step 7 WrapTeflon tape around the threads on the inlet valve, and then screw thewater feeder hose fitting over the threaded section. Secure it by usingthe wrench. Be careful you don't overtighten or you could cause a leak.
  14. Step 8 Turnthe water back on to check for leaks. If no water droplets appear, thensecure the water inlet valve to the housing of the dishwasher with thetwo screws you removed earlier.
  15. Step 9 Slide the wire connector over the terminals on the valve and replace the front access panel covers.
  16. Step 10 Turnthe circuit breaker back on and run your dishwasher. You should hearthe valve opening up to release water into your dishwasher as the cyclebegins.
    regards
    iversh
    A very helpful rating is appreciated for responding to your
    query....
Posted on Aug 30, 2009
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
Mar 24, 2018 | Whirlpool Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
What does F1 fault code mean?
Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
Jan 08, 2010 | Kitchen Ranges
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Dacor Epicure IDW30 Built-in Dishwasher Logo
606 people viewed this question
Top Dacor Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
