How to change living solution alarm clock from 12 hour to 24 hr
Posted by kelly crawford on
5 Related Answers
Anonymous
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
yixdfyixd
SOURCE: Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Posted on Mar 13, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Changing from 12 hr to 24 hr on a Casio Data Bank 150
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please ...
Posted on Apr 02, 2010
Anonymous
SOURCE: I have a blue hat toy co. time and space
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
Posted on Dec 27, 2010
Pete Yocum
  • 3 Answers
SOURCE: I have an ultmost model
Make sure the clock is in the normal clock-display mode, not in a "set" mode. Press the minute key (again, while not in a set-anything mode) and you will see the hourly announcement toggle on and off. The person who designed it that way needs a good kick right in the bracket.
Posted on Oct 18, 2011
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Radio Shack atomic clock 63-1438. How do I set it for 12 hr. time rather than 24 hr.?
Some clocks of this type have a 12/24 selection switch on the back.
Dec 28, 2015 | Home
How do you switch between A 12 hr clock or 24 hr clock
Some clocks are only 12 hour and some 24 hour and others have both options and this you will find on the inside of the clock on the movement. If there is no option on the movement then you cannot change it.
Aug 08, 2013 | Electrical Supplies
This clock is an automatic set clock and it is 15 minutes ahead in each timezone and is not able to be reset by us
Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
Aug 08, 2011 | Equity Time USA Insta-Set 44200 Clock...
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Jan 27, 2011 | Bose Audio Players & Recorders
I have a blue hat toy co. time and space projection alarm clock. it says it is a 12/24 hr clock but we can only show military time. is there anyway to just show the 12 hr clock. it is confusing to my son....
Dec 26, 2010 | Sharper Image Blue Hat Toy Company Kids...
Sangean PR-D3L - How do I change between 12 and 24
Archer, I have read the entire PR-3DL manual and there appears no mention of a 12/24 hr setting, unlike certain other Sangean radios. The instructions for setting the alarm do not mention 'a.m.' or 'p.m.' .
Apparently, the clock is a 24:XX:XX display only.
Apr 05, 2010 | Sangean ATS 505 AM/FM/SW Radio
Reads 24 hr instead of am and pm
Push and hold alarm time button to bring up “SETUP MENU”. Push the right tune ">"button 3 times and that should bring up the 12/24 hour display. Push the time + button to set back to 12 hour time.
Mar 05, 2009 | Bose Wave Radio
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
