Question about Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill
It squeaks when I am running on it. The sound comes from the right hand side. When the mill is on and conveying, there is no squeak. It only squeaks when I am running on it. I have only used the treadmill for about 6 months or so.
Posted by larabligh3 on
  • Anonymous Mar 19, 2014
    When running on the machine or if you bounce up and down when it is not going, the front half is squeaking badly. How can I stop this?
  • Be Hancock
    Be Hancock May 16, 2014
    tightening the hinge is a good idea, but it didn't work for me. My Apex 6500 also had a squeak in the right front corner, so loud it ruined running. The hex nut on the left side of the roller was very tight. The hex nut on the right side was spining, so I took off the cover and tightened the hex nut by holding the opposing nut. That fixed the squeak. I made this up. I didn't look at the manual so i can't say that it won't wreck your machine.
mlkary
    New Friend:
  • 31 Answers
Tighten the 2 bolts that attach the hinge to the deck in the right front corner
Posted on Jan 16, 2010
2007 cadillac esclade ext front end squeaking.
well it can still be anything, locating a steering/suspension noise can be hard. Based on what you typed, what first comes to mind is the steering pump is worn out. If it is more of a low whining sound instead of squeaking, its probably the steering pump.
Nov 01, 2016 | 2007 Cadillac Escalade Ext
My 2003 3500 Dodge Cummins diesel Turbo has a squeak in the front tire area that is only squeaky when I turn the wheel left or right very high-pitched squeak like rubber contact I hit a hole and now I have...
It's more than likely the ujoint in the front by the knuckle...You can jack your truck up and turn the wheel to the side it is squeaking the most. Turn the tire by hand and see what it feels like.If your u joint is bad it will bind when you spin your tire.
Jul 21, 2014 | Dodge Cars & Trucks
Treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Jul 18, 2012 | Reebok Exercise & Fitness
98 ford escort sport makes a squeaking sound when running idle or when not accelarating the sounds comes from the passenger side of of the engine
Have you checked the belts attached to the alternator? A worn belt can squeak anytime, especially when wet and occasionally the bearings inside the pulleys squeak if not lubricated.
Mar 02, 2011 | 1998 Ford Escort
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 12, 2010 | GE DBXR463GB Gas Dryer
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill Logo
2,618 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
