Cars & Trucks Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a diagram to put rear shoes back on.
I took the rear shows off to replace but now I am not too sure how they go back together. I need an exploded parts view of a 2003 grand Caravan Sport with 3.3L engine and read drum brakes
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1525
Points
Go to www.autozone.com register yourself and your vehicle then look around the site until you locate repair guide section, follow the instructions. I'd advise printing every page of instruction and read it first.
One piece of advice - if it's your first time for anything on the vehicle and there's another identicle assembly, take only one (1) apart so you have a sample (hopefully correctly assembled) to refer to.
Good luck
P.S. Let us know how you make out.
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on Aug 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
35029
Points
261
You should go to any parts store and get a Haynes Manual for your specific car it will have diagrams and all you want to know, (About 20 bucks)
Jordan Waldrop
Level 2:
Scholar:
  • Expert 147 Answers
Jordan Waldrop
Expert
Level 2:
Scholar:
Answers
147
Questions
Helped
61585
Points
408
You local dadge dealers parts department should be abole to print the exploded view for you. Hope this helps and good luck
I put new shoes on 2004 pt cruiser base model and did some adjusting and bled the brakes now the drum wonā€™t fit back in and Iā€™ve already had it on once before I only took it off to make sure both sides...
With any style of brake (drum or rotor), new shoes/pads will always be thicker than the ones you are replacing. You have to retract the brake cylinder pistons to get drums/calipers on. For drum brakes, squeeze the two shoes together at the brake cylinder. If there is no more play and it still won't go on, the shoes you are using are too thick - this can happen with certain aftermarket parts. Try the OEM shoes instead.
2answers
Rear brake shoes 2002 Isuzu Rodeo. My friend took both sides off and know wnats to put it back together. I have no diagrham
the rear brake shoes are very similar on most vehicles so any isuzu workshop manual will have diagrams and photos on the rear drum brakes
Tell your friend to leave the vehicle alone if he doesn't know what to do as it is your life he is messing with
2answers
Rear brakes
Removal
1.Remove rear wheel and tire assembly from vehicle.
2.Remove rear brake drums from hub and bearing assemblies after loosening the two brake drum screws.
3.Be sure that the parking brake pedal is in the release(most upward) position.
4.Completely loosen square nut of the rear parking brake cable. Then create slack in the rear parking brake cables.
5.Remove adjuster spring from adjust lever and brake shoe.
6.Remove adjust lever and turn the adjusting wheel of adjuster assembly to the direction of the arrow as shown.
7.Remove the strut spring and the lower retracting spring from the brake shoe.
8.Remove the upper return spring from the brake shoe.
9.Remove brake back plate hold down spring and pin from the leading brake shoe assembly.
10.Remove the leading brake shoe. Then remove the adjuster assembly, strut and anchor spring from the trailing brake shoe.
11.Remove the trailing brake shoe from the brake back plate after removing hold down spring and pin.
12.Remove the trailing brake shoe from the rear parking cable.
13.Remove parking pivot lever from the leading brake shoe.
Replacement
1.Lubricate the eight shoe contact areas on the back plate and anchor.
2.Install the trailing brake shoe to the rear parking cable.
3.Install trailing brake shoe on brake back plate and install the trailing brake shoe hold down spring and pin on the brake shoe.
4.Tighten the square nut of rear parking cable.
5.Install the anchor spring then install adjuster assembly, and strut.
6.Install leading brake shoe on brake back plate.
7.Install the brake shoe upper return spring, strut spring and the lower retracting spring to the brake shoe.
8.Properly rotate the adjusting wheel of adjuster assembly to the direction of the arrow in as shown.
9.Install the adjuster spring on the adjust lever and leading brake shoe assembly.
10.Install the leading brake shoe hold down spring and pin on the brake shoe.
11.Adjust brake shoes assemblies so as not to interfere with brake drum installation.
12.Install the rear brake drums on the hubs.
13.Check and adjust whether the pedal stroke in the specification.(Refer to section BR Gr./On-vehicle service/Pedal stroke of parking brake)
14.Install wheel and tire.
15.Push the parking brake pedal to the floor once and release pedal. This will automatically remove the slack from and correctly adjust the parking brake cables.
16.Test the vehiche on the road. The adjust will continue the brake adjustment during the road test of vehicle.
Inspection
1.Inspect the disassembled parts for wear, rust or damage.
2.Measure the thickness of brake shoe lining.
Standard : 0.17 in (4.5 mm)
Minimum : 0.04 in (1 mm)
3.If the shoe lining is less than minimum or shows signs of uneven wear, replace new one.
4.Measure the inside diameter of the brake drum.
Standard : 10 in (254 mm)
Maximum : 10.07 in (256 mm)
5.If the inside diameter of the brake drum is more than maximum or shows signs of uneven wear, replace new one.
6.Inspect the lining and drum for proper contact. If the contact condition is improper, repair it with a grinder or replace the brake shoe assembly.
Brake shoes
Hi, not sure if you will be able to get a diagram or not. If you are looking to do your brakes yourself, you can block up one side of the car and pull the brake drum off. Once the drum is off, you will be able to see all of the parts and how they go together. Then jack up the other side and replace the brake shoes. Use the blocked up side with drum removed as a reference when putting the other side back together, then switch sides. This is how I have done it before and it works really well...maybe better than a diagram.
Rear brake shoe installation need diagram to put back together
autozone.com sign up its free then click on repair manuals you will find all of your info there....good luck
Need diagram for rear brake shoe replacement on 2000 Dodge Caravan. Took both sides apart and now having difficulty putting back together. Thanks
Go to any auto parts store and buy a Haynes Manual (Around 20 bucks) for your auto, it will have evything you want to know
Very poor brake performance after changing rear shoes
It sounds like your self-adjusters are not assembled correctly allowing them to back off when braking.
How do i replace the rear brake shoes
FIRST JACK THE CAR UP THEN TO PROCEED TO TAKE OFF BOTH WHEELS IN THE REAR. CHECK BRAKE SHOES TO MAKE SURE THEY NEED REPLACEMENT. YOU WILL HAVE TO HAVE CERTAIN TOOLS TO REMOVE THE 2 SPRINGS OR YOU CAN USE PLIERS. IT'S EASY TO TALE OFF ONE SIDE OFF AT A TIME. THAT WAY IF YOU NEED TO CHECK THE ONE SIDE YOU JUST LOOK AND SEE IF YOU PUT ALL THE SPRINGS AND HARD PARTS BACK TOGETHER.
4helpful
Looking for diagram of rear brakes - doing brake job
Pull both wheels off, do one at a time, use the other side as a guide to put it back together, I am a retired auto mechanic and this is the best way to do the job, also remember the larger shoe always goes to the back.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
