I am able to see buttons but none of them are picking up touch. I have tried reset and recalibration. Please advice if I need to change some part or some attaching cable and where can I get that part from
Thanks
Hi, you must change the lance flap, its a problem of lance flap so just replace it and its a ruttin problem,
Hi , can you explain me what is lance flap and how should I be sure the problem of touch screen is coming from this part .
is it that something I can change it myself ? or I should ask workshop ?
appreciate it .
the problem : dcr-hc40e touch screen problem
If
the touch screen of the Camcorder is not working, please follow the
troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to ON for more than 15 seconds,
turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
If the touch screen of the Camcorder is not working, please
follow the troubleshooting steps.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
that helps.
remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15
seconds, turn the Power switch to OFF position and then reinsert the battery
pack.
Camcorder.
