Question about Apple iPhone Smartphone
How can i put music on an unlocked iphone?
Im in the same boat. please somebody help!!
i got an iphone to take w me to asia, but when i plug it into my computer to add music from my itunes, it says that the phone is unsupported. meaning that i dont have at&t. if anyone knows how to correct this i would be a very happy man!
Posted by phanroy1 on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
You can try to reset the iPhone and connect to iTunes again. Or just utilize Leawo iTransfer to reach this aim. Follow below steps.
Step 1. Run Leawo iTransfer and connect iPhone 6s to computer with USB cable.
Add music
Step 2. Add music you like from computer to iPhone 6s.
Note:There are 5 ways to add files from computer:
A.Drag and drop the computer files directly into the window of the software;
B.Right-click music library and choose "Add File" or "Add Folder";
C.Click "File" on the upper right corner, and choose "Add > Add File/Add Folder";
D.Right-click music library and click "Add File";
E.Click "Add" button on the top left, then choose "Add File" or "Add Folder".
transfer music
Step 3. After adding music to the software, it will automatically begin to transfer music from computer to iPhone without iTunes.
For more details, check: How to Transfer Music from Computer to iPhone
Posted on Jul 10, 2019
5 Related Answers
Anonymous
  • 265 Answers
SOURCE: i cant put music in my iphone
Your phone will need to be restored. Un-locked phones are often rejected by iTunes.
Posted on May 28, 2008
Anonymous
  • 59 Answers
SOURCE: How do I add itunes music to iphone from computer itunes library
Yes it can, connect your iphone to your computer, at this point as soon as your computer recognizes the iphone itunes should open up.. if it doesn't just open it up yourself. Now on he left where all the playlists are there should be an icon with you iphone there, click on it. Now to the right there should be a tab labeled "music", click on it now you can select wether all your music will transfer over or just certain playlist. There you go.
Ciza
Posted on Oct 30, 2008
Anonymous
  • 42 Answers
SOURCE: Restore problem with emergency call display all time
Your iPhone is not factory unlocked. This means if you purchased it from the USA you need a deactivated ATT SIM card to get it past the activation or use a program called QuickPWN to Jailbreak + Activate your iPhone
Posted on Feb 12, 2009
270rexton
270rexton
  • 782 Answers
SOURCE: How can i show my iphone 's music in itunes?
In iTunes uncheck the Sync button and the connect your iPhone.
Posted on Jul 29, 2009
Anonymous
SOURCE: HOW TO PUT MUSIC ON AN UNLOCKED IPHONE 3GS
idk sriiiiiiii try to send it back but im trying the same thing with a 2g iphone try putting it in itunes n restore it but uve probully tried dat lollz idk but zipiphone.com will do dat but u mit gotta pay ten buckz it depends on watt u want try it plzzzzzzzzzzzzzzzzzzzzz i sugest it
Posted on Aug 15, 2009
How can I Unlock Iphone 3g 8gb module A1241 FCC ID: BCGA1241 IC ID:579C-A1241?
To Unlock I-phone 3G 8GB use Remote Unlock service...Visit the site
Mobileunlocksolutions.com get remote unlock service and unlock it from network lock easily...
Jul 21, 2012 | Apple iPhone 3G
The buttons on my iphone wont work.
it seems that your phone is hanged. Try connecting the phone to the Itunes and try restoring it.
Jan 01, 2010 | Apple iPhone Smartphone
Getting music from itunes on unlocked iphone
Unlocking does not effect syncing make sure you have most recent itunes. make sure you don't manually mange music if you want phone to sync. when phone plugged in click on phone to see settings make sure sync music is checked
Nov 17, 2009 | Apple iPhone 3G
Cant syn music form itunes
you have to use itunes import your music in there and make a playlist first and make sure you have enough room when you attach your iphone select it and choose the playlist you like to import music.
Sep 12, 2009 | Apple iPhone Smartphone
Problem with my iphone
ok im not familiar with this phone im going by what you say
start computer plug in iphone / goto start /then /computer/ the one thats says usb double click /you should have list of inside ur iphone
vidio
music
and more
now right click and hold on itunes and drag to music/ and release let it load /
unplug iphone goto music open tracks .and play
Aug 26, 2009 | Apple iPhone Smartphone
Aug 15, 2009 | Apple iPhone Smartphone
IPhone Disabled
You can refer to below steps to reset your iPhone. There offers several methods to reach this aim.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
reset-iphone-password-with-icloud-find-my-iphone-noceaq0kid4ty03ndmq2d5rf-1-0.jpg For more methods, check: How to Reset Password on iPhone
Jun 02, 2008 | Apple iPhone Smartphone
My iphone does not turn on
********************** SOLUTION!!!! **************************
If you just see an apple logo or your phone does not turn on, there is a software problem and you will need to restore your iPhone. I didn't want to hear it, because now I had to redo everything; but it's the only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the home button and hold both buttons for 10 seconds. You should hear another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes. Wait for it to tell you that it’s in restore mode. You should also hear a third sound from your computer during this time.
Step 6: Click on your iPhone in iTunes. It should say it's in recovery mode and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
Nov 29, 2007 | Apple iPhone Smartphone
Sansa e260R
Go to best buy.com then under music & movies click music then put vou mouse arrow on digital music then click Best Buy Digital Music Store then click Access to unlimited music › then there u go create ur account
Jun 02, 2007 | SanDisk Sansa e260 MP3 Player
Apple iPhone Smartphone Logo
117 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
