Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
I followed the instruction book to the letter and reinserted the brew unit but it will not turn the "brew unit miss" error off. I have removed and replaced it several times and moved the levers to every possible position but the brew unit will not return to the fully inserted position (althougfh the door closes and seems to be in place. The instruction book is very poor and there are no clear pictures of the brew unit to aid in determiningpossible mistakes)
Posted by cavapatibm on
Anonymous
  • 80 Answers
Check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Posted on Aug 30, 2009
Mischel mutafov
    New Friend:
Press norm & small coffee till digits appear press large coffee till you hear popping
cleanded brew unit as instructed - brew unit miss  - 3_28_2014_11_24_24_am.jpg
Posted on Mar 28, 2014
I'm unable to push the brew unit all the way in. This started when the brew unit was not properly inserted when the machine was turned on causing it to jam. I found the instructions that said remove a...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 14, 2011 | Gaggia Syncrony Logic 74884 Espresso...
The brew unit still won't fit back into the machine. I have clarified the make of the machine as I think you were describing a different machine in the last instructions. I do believe it could be a matter...
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Apr 08, 2011 | Saeco Incanto Sirius Espresso Machine
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
Hi, My Gaggia Titanium shows a Brew unit missing error. I have tried everything i can think of; - cleaned the inside - removed and inserted brew unit multiple times - switched machine on/off (including...
Try taking the brew unit out, and clean the area inside the machine for coffee grains before reinserting it. There's a tiny sensor for if the unit is inserted, but it can be confused if the machine gets messy inside.
Aug 18, 2010 | Gaggia Titanium Espresso Machine
Have cleaned the brew unit and the machine still does not work
If you are holding the brew unit in you hand look at the top you will notice a small knob with grooves, if you look to the bottom of that knob about 3-4 inches inside the unit you will see the screen. If it is no noticeable run water from the faucet over the brew unit.
Oct 06, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
Brew unit missing
post your email i will send you the guide that shows you how to properly install the brew head
May 30, 2008 | Miele CVA615 Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
3,127 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
