I have an Amana fridge ARS2663AW. The water dispenser dispenses water, however, there is not water going to the ice maker. It runs and tries to flip the ice out..... its just that no water is being dispensed into the ice maker. What can I check? I have manually poured water into the ice try and it will freeze it and kick it out... just when its time to refill the ice trays... nothing...=/ What is it????
CHECK THE WATER SUPPLY HOSE GOING TO THE ICE MAKER ITSELF ,YOUR HOSE MIGHT HAVE A SMALL BLOCKAGE IN IT,TAKE A LONG PIECE OF THIN WIRE AND RUN IT THROUGH THE HOSE,THAT MIGHT SOLVE YOUR PROBLEM.
It seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Well, the tube from the inside of the freezer that gives water to the ice trays is a white big tube. I did pull out the tube and look inside it and its clear. So, I dont think there is ice built up anywere inside the tube. Weird huh??
