Is there a fix or adapter to allow the Swift Kestrel 826 to be used with eyeglasses?
There are no adaptors for this problem.
The Kestrel should have rubber eyecups. They are fairly thick and stiff but these need to be folded over to be used with glasses.
If that isn't working for you you could try this. Some who wear glasses remove the eyecups. The rubber unscrews. The eyecup is then replaced with the rubber from a bicycle inner tube. Stetch the inner tube over where the eyecups were sitting. This can be cut and folded to the right height to allow viewing with your glasses.
Just removing the eyecup and using glasses may result in you scratching your glasses on the metal eyepiece.
Testimonial: "I'll give it a try"
I hope it works for you. There are some noted binocular officionados who use this method. The Kestrel is a magnificent binocular. It was Swifts premium 10x50. It was also called the 10x50 Audubon making it a 'big brother' to the landmark 8.5x44 Audubon. Although not having the resolution of the 8.5 it is still highly regarded. I hope you get many years of great viewing pleasure from the Kestrel.
