Sony Handycam DCR-HC32 Mini DV Digital Camcorder Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it possible to use a SonyDCR-HC32 handy cam
Windows Vista is not compatible with this Camcorder. It says USB streaming is not supported. Is there a way to upload video from the camcorder to Windows Vista?
Anonymous
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
246
Questions
0
Helped
102570
Points
760
To use fire wire connection and Windows Movie Maker is the simple way to import video and make movies.
Anonymous
Level 3:
  • Master 10,594 Answers
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955557
Points
33084
Click Sony Support to download Vista drivers that might solve your camcorder connectivity problem.
6helpful
Driver for dcr hc 62e
Windows 7
* Drivers:
o The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
* Not Supported:
o The USB streaming feature is not supported with the Windows 7 operating system.
o The Windows 7 Starter edition is not supported.
Windows Vista
* Drivers:
* Not Supported:
o The USB streaming feature is not supported with the Windows Vista operating system.
o The Windows Vista Starter edition is not supported.
* View Detailed Windows Vista compatibility information.
Windows XP
* Drivers:
* Not Supported:
o The Microsoft Windows XP 64-bit operating system is not supported.
o The Windows XP Starter edition is not supported.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
How do I import video from my sony handy cam DCR HC32 via USB to my computer
You don't. According to Sony, your camera will not stream video via the USB port. You can only do this using the i.Link connection (what everyone but Sony calls Firewire). The list of camera models that will stream via USB, and the method to do it, is on THIS LINK Your camera is not in the list.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. Or maybe you have a Mac. You haven't said.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select your operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
1helpful
I have a sonyDCR-RV285E handy nd i am new with it.can u help me to transfer pictures rom my handy to my computer????? what r the needed softwares??
Use the Picture Motion Browser Software to transfer the pictures from Handy Cam to Computer.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/help/4300_DSC/300_04/htmlfolder/browsepicture_02100.html
1helpful
DCR-TRV285E Digital-8 Digital Camcorder: i have a sonyDCR-RV285E handy nd i am new with it....
You can download the Picture Motion Browser here:
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&f=PMB_V4303_PICPAC&m=DCR-TRV285E
2helpful
I have windows vista and i cant install the usb driver and pixela programs for this handycam please help me.
the usb driver and pixela application is not compatible with windows vista. usb streaming is not supported by windows vista and 7 OS. however it would still be possible to transfer videos from your dv camcorder using the dv interface (ieee1394 or ilink) connection. you would need to have an ilink (ieee1394) card installed in your computer. you can check by going to device manager window. if you don't, try checking with your PC manufacturer recommendations for an ieee1394 chipset or card.if you do, all you need is an ilink cable (btw, the cam uses 4pin jack).get the correct cable for use with the PC and camcorder, and use windows moviemaker for your video capturing software.hope this helps.thanks :)
also, here's the support site for your unit:
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-PC101E
1helpful
DCR-TRV355E Sony Handy Cam not recognizes by Vista o my 32 bit HP lap top (New)
If you are using the USB cable to connect the Camcorder to the Computer to transfer the videos to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer.
The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video to the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!
Usb handy cam is invalid when i connect my camcorder to my pc
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
2answers
Need drivers for using sony handicam digital as streaming webcam on windows vista
If it is Sony DCR-TRV250 camcorder then it can be used with Windows XP through USB Streaming port and no driver update is available so far for Vista. Check further details on Sony Support.
Thanks.
2helpful
I have picture package 1.5 but when i want to convert the tape to cd, i can not select the source and target is there a patch for this ? This for DCR-HC32 E Also i have now bought a new laptop which has...
The supplied Picture Package software is not compatible with the Vista Operating System.
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Good Luck!!!!!!!!!!!!!!!
1helpful
SONY HANDY CAM DCR-HC18E PAL Need download for usb driver windows vista
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-HC18E&sec=DV
Only load the driver and install in XP compatability mode then use another video capture programme Sony does not support Vista for you cam.
FX vid capture will work
http://www.jhepple.com/video_capture_software.htm
If you get stuck you can reach me on [email protected]
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
