No water going in the ice maker but water dispenser work fine
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
SOURCE: Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
SOURCE: Dispened Ice
try lifting up on the lever while pushing in.Works for me.Also be sure the ice tub is all the way in good luck
SOURCE: water dispensing but also leaking from the back
Pull the fridge out and remove the back panel . Have someone press the water dispensor and watch for the leak . Usually , the plastic line at the water valve breaks off , and removing the broken piece and reinserting the line , fixes it . You may have to remove the 1 screw holding the water valve on , to gain access to remove the broken piece of line . The water valve itself , could also have a hole in it , spraying , due to long period of water pressure . Just replace the water valve , if this is the problem .
SOURCE: ice dispenser will not dispens ice . light dims
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
