K7s741 mg no video output
Foxconn K7S741MG-6L Motherboard, 2004 new day1 relic?
is this true?, and yours or posted wrong model?.
NO VGA out? at mobo or the video card?
yes k7 , winfast board>?
answers,
SIS chips there are not supported, by (ALL)
No PCI-express slots at all , just AGP.(BAD)
1/2 of all AGP cards made will not work here, (dang)
no SATA ports, just relic IDE(PATA). sad max.
and the coin cell is dead at 10 year old now 2014
2014-2004=10 , spec is 7 year life so its dead and now BIOS goes MAD.(even igpu dead vga rear)
just found a raw mobo in a garage sale>??sure.
foxconn DIY sales, went dead 2012.
no video connected how , NOT TOLD , fail.
and now double dead, the mobo ended all support, gee how can they if SIS died. really/? nobody can !
and this too DEAD....
https://www.foxconnchannel.com/
buy a i3 mobo 2010 and newer
never buy into, SIS, VIA or Nforce ever.
it's junk mobo for only XP.
I will now tell this, horror, back in 2004 !
the VGA out is hard to get working on most then.
let me tell you why, (yes horrors of AGP)
1: 1/2 the AGP cards fail here unless from Foxconn.
2:the bios must be forced to the VGA you want to use and there are 3 choices then, igpu ,agp and pci slot.
one is the default and there was NO AUTO mode then.
best is to reset the MOBO using a new fresh coin cell RTC battery and then no APG card there at all.
and hope the igpu works.(mobo rear edge I/O plate VGA)
3: on some mobo (yes) I had to use very old PCI card, like this one for $10 used
ATI Radeon 9000 64MB PCI Video Graphics Card, With VGA, DVI & S-Video
this last trick if needed allows VGA bios to work
and then in the BIOS video page set it as you want
end legacy ,topic, PCI (non-express) video.
PCI old, is gone and forgotten now.
PCI-express modern/ 2003/4 up.but not yours.
avoid all AGP. the maker had a QVL on AGP that shows, only tiny list of allowed, and is max pain all that.
even bios updates that do not exist now..
All the voltages are ok..only 2 were off by .2
No swollen capaciters visible on Board..
Do you have a power supply tester? You need to make sure all the voltages are present. Also, are the tops of any any of the capacitors "swollen"?
