Question about Krups Small Appliances Espresso Machine
TRYING TO FIND THERMAL FUSE. MICROTEMP G4A00 TF216C
IT IS FROM A GE COFFEE MAKER. RADIO SHACK HAS A 128C AND A 140C THERMAL FUSE. CAN I USE EITHER OF THEM?
Posted by grant9129 on
  • Matt Bishop
    Matt Bishop Apr 10, 2015
    i have a microtemp that is 240c i'd mail it to you if you want i have no use for it i just like tinkering
  • Matt Bishop
    oh i just seen date lmao in 6 years if you haven't found one i hope like hell you gave up lol
Jim Peak
    New Friend:
  • 3 Answers
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Posted on Jun 01, 2013
Ross Keen
  • Krups Master
  • 1,364 Answers
Http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2051337.m570.l1313.TR0.TRC0.H0.XThermal+fuse%2C+216+deg+C.TRS0&_nkw=Thermal+fuse%2C+216+deg+C&_sacat=261
That is your thermal fuse, anything lower temperature than that will be useless. Give some thought on how you are going to attach it to the wires, you cannot solder it on, the heat will travel to the fuse & blow it plus over time with the boiler heating it up to close to fail temp the solder will release.
Posted on Apr 10, 2015
Virgil Wolter
  • 29 Answers
The 216C is correct for this use. Any less would fail. This fuse prevents the element from burning out. The high limit is needed as the part this touched gets a lot hotter than 212 degrees. This is needed to boil the water. Keep searching online for the correct size.
Repair to my coffee maker was done with a slightly higher rated temperature fuse (218) found at Radio Shack. The fuse was installed with crimp connectors I found while searching the Radio Shack stock. The crimp connectors are used as the heat is too high for solder connections.
Posted on Jun 07, 2014
Anonymous
  • 3 Answers
Those thermal fuses are much too high a temperature. The standard temperature for brewing coffee is less than 200 degrees Fahrenheit. This would equate to 93 degrees Celsius. Your 128C would allow the coffee maker to get to 262 degrees Fahrenheit. This is too hot. You need to find something more in the range of 80-90C. Good luck.
Posted on Feb 04, 2010
  • Jim Peak Jun 01, 2013
    Note: I believe that YoTeach's 2/4/2010 solution is incorrect, when advising about the thermal fuse. Please see my post, dated 6/1/2013, for details: Jim Peak
  • Virgil Wolter Apr 10, 2015
    I agree that YoTeach is incorrect. My post dated 6/7/2014 has the information about this.
I need a couple microtemp fuses 240 degrees C G4A00 for the wolfgang puck swivel waffle maker.
Radio Shack has a 228C and a 262C.
Google '240C thermal fuse' for online purchasing.
If you live near an urban area, try an appliance repair facility or electronics supply.
Feb 28, 2011 | Vacuums
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
Wont heat or brew!!
Make sure the coffee maker is unplugged there's 120 lethal volts inside when plugged in!
This unit has a replacable thermal fuse. It's a "Microtemp" Thermal Cutoff Fuse G4A00. You can buy five on eBay for $2.70. There are two on this unit and they are in the base concealed inside a 3" white mesh that runs alongside the heater. You will need a security fladebladed screwdriver that you can make by filing a notch in the center of a regular screwdriver.
Jun 28, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
I have a hamilton beach brew station, and the coffee won't get hot. Any suggestion?
There is a Thermal Protector Fuse at one end of the brewing element that overheats and is designed to fail(Either at 128C, 140C, or 228C).
It is likely that one of these is the culprit.
Some coffee makers have 2 different ones. The part costs about $1.70 at a local electronics supply or online. Taking apart the coffee maker is a chore, but can be done if patient. The fuse must be soldered back in place carefully. Getting it too hot will ruin the new one. If you have no technical background, I wouldn't suggest trying to fix it yourself.
Alternatively:
If the coffee maker is less than 2 years old, you can call Hamilton Beach and they will give you instructions on how to RMA your coffee maker.You need to give them the code # on the bottom of the unit. They will request that you cut off just the plug and send it to them with a check for return shipping costs.
May 19, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Clicks when turn on will not get very hot
I have had the same thing happen to TWO of mine.
There is a Thermal Protector Fuse at one end of the brewing element that overheats and is designed to fail(Either at 128C, 140C, or 228C). Some coffee makers have 2 different ones. The part costs about $1.70 at a local electronics supply or online. Taking apart the coffee maker is a chore, but can be done if patient. The fuse must be soldered back in place carefully. Getting it too hot will ruin the new one.
Alternatively:
The latter is much easier.
May 18, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Brews 1 cup at a time
The Micro fuse is opening and closing and almost completly gone.
The Micro fuse is shorted open. There are two underneath the housing. They are made byMICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. if not you've identified the defective fuse. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces. As cheap as they are I would replace both at the same time ($1.50 each).
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers. Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Mar 10, 2009 | GE 106591 Coffee Maker
Coffee maker clicks but does not brew
This information is for the GE model number 169164 12 cup digital coffee maker.
The Micro fuse is shorted open. There are two underneath the housing. They are made by MICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. If not you've identified the bad one. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces.
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers.Reassemble and your back in business as a Barista.
Nov 16, 2008 | GE 106591 Coffee Maker
I'm having some of the same problems
2001 blower (Air Or Heat) only operates on high
Behind the glove compartment right hand dash( just remove glove box liner) is a metal box of resistors which select through the Heater /AC switch called the heater control unit. Inside there is a thermal control diode/resistor
Small silver cylinder which can be replaced (or bypased because it's amperage rating is low)
Or Replace the whole heater control unit Plugs in
[email protected]
Sep 10, 2008 | 2001 Dodge Caravan
Whirpool rbd275yPDT11 no power after auto clean
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Jul 05, 2008 | Whirlpool GBD307PDS Electric Double Oven
Krups Small Appliances Espresso Machine Logo
7,153 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
