Panasonic KX TGA270S Cordless Expansion Handset Logo
Posted on Aug 29, 2009
Want to be able to lift panasonic kxtga270s cordless phone off
Charger for incoming call and  have to push talk button to speak not automatically get connected as soon as i lift the phone off the charger
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1631
Points
Press the function button (lower left) arrow down to i"Initial Settings" , arrow right, arrow down to "Auto Talk" arrow down to "off" press "Save"
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
1helpful
2answers
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
1helpful
Is it possible to do 3 way calling with the Panasonic KX TG6071B
Not unless the phone as 2 lines but u have to call the both people or the person you called can but it go's both ways you just have to press the talk button then call someone then press talk again then call that person then press talk again and you all three should be on the same line
1helpful
Panasonic kx-tg2357
Called Panasonic Support. The unit will NOT record voice messages whilst in talking mode.
3helpful
RE: Model #kx-tga931t telephone Panasonic brand
Press: menu scroll down to talking caller id press select scroll down once till you see "off" press select You have to do this on each handset
Same phone next door
You and the neighbor may be resetting to the same default channel when setting the phone back on the charger. When yours comes off-charger, push the Talk (On) button and hit the Channel button a couple times. Hopefully that will put you on another channel or frequency hopping sequence (if your phones use this feature).
Call Waiting problem
wow..that's a cool feature..did you program it that way?
good thing it doesn't just bring them into the same conversation(autoconferencing)..
so is this an issue or are you just letting us know?
6helpful
Panasonic handset please lift up and try again error
According to the manual when you get this message
Please lift up andtry again.
A handset button was pressed while the handset was
on the base unit or charger. Lift the handset and press
the button again.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
