Question about Cycling
Diameter of seat post of a ccm targa - Cycling
Posted by Ren Ouimet on
2 Related Answers
rigger094
  • 188 Answers
SOURCE: what is the seat post
if you have the old post,it is written on the bottom
Posted on Oct 25, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: i need to know the seat post diameter so i can
It's etched in the old seatpost.
Bontrager SSR, micro adjust, 27.2mm
http://fisherbikes.com/bike/model/wahoo.
Posted on Mar 26, 2011
What is the vas,fs,pe,qes and qts for a 8000 watts targa venom sub woofer?
5000w Peak PowerSPL (Efficiency, 1W/1M) - 89.1dBNominal Impedance - 2/4/8 OhmsQts (total speaker "Q") - 0.42Vas (Equivalent compliance) - 75.9LMounting Depth: 156mmMounting Hole Diameter: 280mm
Oct 22, 2016 | Car Audio & Video
I need a seat for a Nel Lusso can I buy it separately?
most bicycles have saddles with standard ~1/4" diameter rails that can be interchanged on any bike. Caveat emptor: I do remember seeing some Huffy bikes back in the '80's and '90's that had flat vertical blade like rails that were only used by Huffy. If that is the case you can always get a new seat post (make sure you get the right diameter to fit in the seat tube, it's stamped on the seat post near the bottom) and a new saddle that will work with the seat post. Any local bike shop can help you get the right size and fit that you need. ($15+ for a seat post, $30+ for a saddle).
Oct 18, 2015 | Huffy Cycling
Lost the sound on my targa tv
kielybarry,
Somehow your Targa TV problem was posted in Desktop PC's.
Would wish you to repost in - Electronics > Televisions & Video.
Regards,
joecoolvette
Mar 01, 2013 | Targa Computers & Internet
Ccm tl 125 fork seals
normally if you remove the seals carefully there are numbers printed on them and also you can measure the outside diameter and measure the fork slider to get any info required ! if you google ccm uk there should be someone with spares ! if you struggle let me know and im sure i get anything you want !! P...
May 24, 2012 | 2009 CCM TL 125
How to get a giant trinity a1 tt seatpost?
Bicycle seat posts are pretty standard items and you could just use a generic replacement if you want as long as you get the right size diameter.
If you still have at least part of the old seat post, then just use some precision calipers to measure the outside diameter of the seat post and that will tell you what size replacement you need to get.
This needs to be a pretty acurate measurement, within a tenth of a millimeter, so eyeballing it with a ruler just won't do it.
Otherwise, if you are missing the old seat post entirely, then you can try just measuring the inner diameter of the bike frame where the seat post slides into your bike tube and you should get the same measurement.
The easiest way by far is just to bring the bike into your local bike shop and get them to measure your seat post size with a special seat tube measuring tool they have. Then you can just order a new seat post based on that size from wherever you want, either right at the store or online.
Good luck and take care.
Joe.
Dec 14, 2011 | Giant Bicycle Inc. Trinity A1
Cycling Logo
182 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
