Spacing on my Stentura 400 srt machine needs adjusting and not sure how to do it?
Posted by irmacazares on
Anonymous
    New Friend:
Depress S- with the machine off, and then turn it on. When it's on, L- is less and M- is more. Fix it to your liking and then stroke N- for no (don't save changes) or Y- for yes (save changes).
Posted on Dec 08, 2009
What type of foot do I need when attaching popper closure tape to a duvet cover.It needs to leave more space under foot for popper height.
You do NOT want to sew over the popper. Instead, use a narrow zipper foot and adjust your machine needle to stitch just on the very edge of the tape. Hitting a popper will definitely break your needle and possibly knock the machine out of time.
Be sure to get the right foot to fit your machine!
Your machine's zipper foot may not look like this, but it should give you the basic idea.
How to Use Zipper Foot Sewing Parts Online Everything Sewing Delivered...
Zipper Foot Adjustable Low Shank 55411
How do I move Needle and foot (sewing head needs adjusted) towards back of machine.
Unless something drastic has happened to your machine, ie dropping on the floor, the head should not need adjustment. Not sure what issue it has, or what symptoms it is presenting. Have you checked that the needle is installed correctly? There is a flat side to the needle that needs to face a certain direction on your machine--most often the flat side faces the back of the machine, but on some machines, it faces the harp space of the machine. The Owner's manual should have an explanation.
1helpful
BLANK LED SCREEN ON STENTURA 8000
plug in a moniter if you get a picture the screen has gone ,new screen or use with moniter
Can you reset a Stentura 8000? It's stuck "Recovering Files"
If you were indeed talking about the Stentura 8000, and not the computer, and if your writer boots up ok but gets stuck at "recovering files" **when you try to start writing**, try verifying that the floppy is good (e.g. looking at it via a computer)- it may just be that the floppy got fried in the power surge. You can try using a fresh floppy (check in Windows/etc to make sure, first). There are many floppy-recovery programs out there on the web, and that'll at least get your Stentura sane again. Just dealt with this a few minutes ago, and that's all it turned out to be...but after 3 months, you've probably long since found your own solution.
Im having a problem w/my stentura 8000 when i plug it in, the power goes in and out and im not sure why. ive tried 2 different power plugs and its still doing it. also i havent put a new battery in it in a...
Hi
Your power adapter on the motherboard needs to be re soldered or replaced because they all come loose and move.
the problem could be finding the part and the labour cost to do it, get a few quotes and consider if its more cost effective to replace the laptop or repair.
cheers
1helpful
Hello, I'm trying to display Arabic srt subtitles ...
If you have Arabic lang. in your windows, and you have the movie (.avi) and the subtitle (.srt) in the same folder with exactly the same name for both 2 files, and you use VLC as media player .. then:
1-Download (Subtitle Edit 2.9.3) software .. it's free!.
2-after setup .. open the subtitle (.srt file ) and adjust "defult file encoding" (same window-left side) to: UNICODE
4- Save (from file tab).
5- You can also adjust the time (later or earlier).
In case you have any questions, my e-mail:
[email protected]
Enjoy..Regards
Ahmed Hosny [Egypt]
Can't change f-stop to higher numbers
That tiny silver post on the front of the body moves the pointers inside the body so you can see in the viewfinder where the aperture is set. It should move far enough that it lets you set 1.7 to 22. Check it to be sure the internal display matches the lens setting.
If it matches, and won't let you go all the way over, check the track for obstructions. Remove the lens and check the silver tab. It should go past the A in MINOLTA. Does the tab move all the way with another lens?
It sounds like something internal is blocking the movement of the ring or its linkage on the SRT.
I suggest a trip to the repair shop for the SRT. Garry Airapetov in Niles, IL repairs them at a very good price. He will fix it, clean, Lube, adjust it, and return it for around fifty dollars.
Look up Garry;s camera repair online to check prices and download the form you send with it.
He did a really good job with my SRT 101.
lightspiritphotography.com
Dec 10, 2009 • Cameras
Clearance for inlet and exhaust valve adjustment
Not sure about clearance levels, but can tell you there is no English manual for the XJR 400 - only Japanese. Try the XJR owners club. It's full of troubleshooting questions answered in the forums.
Hope this helped
Danger :)
Dodge srt 4 emergency break needs adjustment
This type of e-brake should actually adjust each time you engage it. If it no longer holds,the e-brake shoes may need replacment, or the friction surface they contact maybe rusted and not able to hold properly. I recommend you see your mechanic about this. Contact me nd let me know how you make out, or if you need further help.
 Grubhead
Grubhead
Marvin
Marvin
