Question about Vizio Televison & Video
Vizio TV turns on then screen goes blank
TV turns on, screen turns blank, shine a flashlight to the screen, you can see images faintly. If you hold down mute for a few seconds and then press the input button the screen will come back but then will shut down again.
Posted by Dave Salvi on
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
gymowner
George Bill
  • 679 Answers
SOURCE: Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Posted on Apr 09, 2009
Anonymous
  • 208 Answers
SOURCE: Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Posted on Sep 02, 2009
Anonymous
  • 21 Answers
SOURCE: we just set up our 37 in sharp and get no picture
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
shltech
SOURCE: Sharp LC37D44U Power LED was flashing green. TV
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Posted on Apr 08, 2011
Why won't it turn on?
While it is on, shine a bright flashlight on an angle across the surface away from you. Can you see any faint images on the screen. If yes, then possibly the back lit lamp / board needs to be replaced.
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
Nov 25, 2015 | Televison & Video
60inch lg faltscreen that after 13 months decided to act up. The entire screen goes blank but the sound is still working.
Power inverter board issue, capacitors might need to be replaced. When the TV is on hold a bright flashlight really close to screen if you can see a faint image that is your problem.
Nov 16, 2013 | Cooktops
Dp32648 picture goes black, tv stays on with sound.
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture? If you see a faint picture, you have a backlight fault. Could be several things, you could have a bad backlamp, defective inverter, defective 24vdc power supply, or a faulty main board. I would highly recommend you get a diagnosis
Apr 05, 2013 | Vizio Televison & Video
Black screen with sound
Turn on the set, dim the lights in the room, shine a bright flashlight on the screen. If you see a faint picture, you most likely have a fault in the backlight circuit. Are you wanting to repair this yourself?
Mar 07, 2013 | Vizio VO47L 47 in. LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Why does my Vizio E470VLE LCD TV have no picture but it does have sound?
you may have a backlight problem. To verify this, dim the lights in the room. Turn on the set and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight fault.
Jan 21, 2013 | Vizio E470VA 47 1080p 120Hz LCD HDTV
Viziov047l sound but no picture
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint image on the screen?
Jan 05, 2013 | Vizio 42 in. LCD TV
Screen black, no video have audio. Went black at some point when I was distracted. Have tried unplug/pause/repugnant - no help. On/off did nothing either.Vizio, Mdl- VO320E, LCD. Not listed on your...
You need to perform the flashlight test. Turn off the lights in the room, turn the TV on, take a bright flashlight and shine it on the screen. Do you see the faint image on the screen?? You could have a defective backlight inverter, defective power supply, or a main board issue. You set will require diagnosis to determine.
Jun 04, 2012 | Televison & Video
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
Acer 22W monitor goes blank after a couple of seconds. Please help.
tjpartners, Have you determined if your display is BLANK, or just BLACK!!! Yes, it can be both! But sometimes if you shine a brite flashlight about 1" from the screen you will be able to see if the screen is only BLACK, but not BLANK because you can still see a very faint image of the Win-Desktop if you look closely. If you see the image then that means the "switch-mode-power-supply" is only in partial shutdown mode and trying to save itself from a catastrophic, nonrecoverable failure! Do the flashlight trick and do a repost to your original message if possible. 12fixlouie
Nov 05, 2009 | Acer Computers & Internet
Televison & Video Logo
43 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
