I have hi home cameras 1080p, how do I change my Altice one to a 2.4ghz setting?
Posted by Theresa Sheehy on
1 Related Answer
SOURCE: Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
Panasonic KXTG3611 Phone 2,4ghz knocking sound magicjack plus uses
Posted on Feb 28, 2013
How do i turn on the 1080p without a remote
Hi Patrick
Good luck with that, I believe there is no way of manually changing the resolution of the projctor without the remote, I have also looked for a replacement remote for this unit to no avail, unfortunately you have purchased a dead duck. and the reviews for this unit are not good.
Sorry
Andrew
Jan 09, 2014 | VVME V06b Led Lcd Projector 1080p Home...
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
Nightowl 8500 500 GB harddrive 8 camera system. I could see the video right out of the box. Set up the VGA cable to a 1080p tv. I changed the video resolution to the highest setting and my 1080p tv will...
The only way is to connect it to a vg computer type screen and then get in the menu if you changed the resolution on your tv you should then get in the tv menu and changeit there
Sep 28, 2017 | Night Owl Optics Night Owl FALCON8500...
How to change my display setting from 720p to 1080p
The resolution is dictated by the video source, if it is fed with 720p, you will get 720p res, feed it with 1080p will display 1080p, just like your PC monitor which is controlled by your PC video card resolution setting, not at the monitor.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 07, 2010 | LG 32LD550 32 in. LCD HDTV
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Every time i try tyo use a specific setting it changes
Hi!
Please remove the Battery from the Camera then press and hold the power button for 30 seconds. Next, reinsert the battery pack and turn ON the Camera.
You may also try resetting the Camera to the original factory settings by follow the steps given below:
Press Home button on the Camera to display home screen.
Select Settings with left/right arrow on the control button.
Next, select the Main Settings 1 then Initialize and OK.
Performing the above steps will reset the Camera to the original factory settings.
If the issue persists even after performing all the above steps then service will be required.
Aug 24, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
