When trying to fax, iam getting a fast busy signal, this problem just strated
Posted by gmrsinc1 on
  • Seth Crosby Mar 13, 2013
    I called Canon about this. They had me tweak the transmission start speed (Menu>FAX setting>TX settings>TX start speed). It was too fast. Set it to 4800. Then it was too slow. Clicked it up to 7200 and now it works!! TX Start Speed should not be too fast or too slow.
Kevin Cole
    New Friend:
  • 45 Answers
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Posted on Dec 08, 2009
2answers
Cant send or receive fax just get a fast busy signal when I try to send fax. please help
Normally a fast busy signal indicates a problem with the phone line. You need to call the phone company and have them do a "line check"
Sometimes they can fix this over the phone, sometimes a service call is required. No charge to you tho.
1helpful
2answers
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
2answers
Every time I try to fax I get a busy signal. I tried to fax several places and I get the same thing cannot be completed as dial.
dial those numbers from a regular phone and listen for fax tones. If you hear a busy signal, then they are busy.
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
2answers
Busy Signal
DO YOU HAVE DIAL TONE ON THE PHONE? IF YES, YOU MAY HAVE A BAD PHONE BOARD. MAY NEED THE HELP OF A SERVICE CENTER. BROTHER TECH
2answers
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
2 phone lines causing problems for fax machine
1 line is fine as long as the fax is set to auto recieve mode
2answers
Cannnot send fax without getting busy signal.
I am having my phone service checked out because I did get one fax to another number.
1helpful
2answers
Busy signal when trying to send fax
of course..is that phone line, by chance a high speed internet connection?
Marvin
Marvin
