Question about Amana Refrigerators
Door does not close tightly. If I lift door it
Door does not close tightly against the rubber that enloses the door. If I lift door by the handle it will move close to the rubber, but as soon as I release handle it moves slightly away from gasket? It was purchased in 2000 from Hallocks in West Haven, CT. Amana TX18VC
Posted by tuturo on
Anonymous
  • 1,305 Answers
If the hinges aren't too worn, you can sometimes loosen the screws (just loose, don't remove) that hold the hinges to the case of the frig, have someone lift the door by the handle.
Have them lift it firmly while you retighten the screws for the door. Your door may fit better and it's a quick fix.
If the hinge is getting worn, you can purchase replacement parts. Check at repairclinic.com ...they have a huge selection and the parts can be matched to their photos... great help when making sure they're correct.
Best of success on this.
K
Posted on Aug 29, 2009
The freezer door is not closing well, and therefore it stays partially opened increasing the freezer temperature sometimes to 30 degrees or more.
Jose,
One of the things that I do when I install refrigerators & freezers, is to raise the front of the unit about an inch so that it tips towards the back. What I normally do is lift up the front of the refrigerator and stick a screwdriver handle under the front edge and then lower either the legs or the front wheels until they touch the floor and then remove the screwdriver handle. Hope this helps!
May 26, 2015 | GE Profile PSI23NCR Side by Side...
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Sep 01, 2011 | Neff B1421 Electric Single Oven
2007 ford freestar lift gate will not open even though I can hear the lock disengaging. Still feels locked. It is manual open, but cannot lift it, feels locked.
Try pressing the door closed while unlocking and releasing. If the door previously has been slammed shut hard or just due to general wear and tear the latching mechanism can become slightly relocated. This means that when the door closes the door is pressing tighter than normal against the door seal. The compressed door seal will put a lot of strain on the latch mechanism and can hinder its retraction when released. By pressing the door closed and therefore removing the strain due to the door seal you might allow the release mechanism enough freedom of movement to retract when released. If having got the door open then immediately adjust/relocate and lubricate the lock/release mechanism such that you achieve a happy medium of the door closing with a weatherproof seal but not so tightly as to put the latch under a lot of strain.
Aug 19, 2011 | 2007 Ford Freestar Limited Minivan
Adjustment of a Chamberlain WD822KL
The opener is having a hard time operating the door. It sounds like the door is out of balance. The door should stay all the way up at half down and all the way down. You should be able to raise and lower the door by hand EASILY. The opener is only meant to lift10-15 lbs. Thanks BB
Apr 08, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
I need to remove and change to the other side the GE GDL20KCSABS refrigerator door handle. The manual is unclear and there is no screw visible at all and trying to slide the handle up off the mounting is...
The handle does slide up off of the handle bracket where a screw will be visible . Remove the screws and on the other side of the door , remove the faceplate for the top screw and the plug for the bottom screw . These should pop back in the screw holes from where the handle was . If you do not see a small hex screw close to the top of the handle and bottom , then yes , the handle will pop upwards to remove . Dont try by just lifting , pop upwards with your hand or rubber mallet . Remember , these handles were made to be tight on the doors to last a long time without comeing loose .
Aug 30, 2009 | Refrigerators
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
JAguar door handles
difficult to open from outside ?  there is a revised link rod for this
Dec 22, 2008 | 2002 Jaguar X-Type
The driver side back door is closed and i cant get it opened
you may want to have someone put their feet against the door and push while you lift the handle
Dec 14, 2008 | 1993 Jeep Grand Cherokee
Refrigerators Logo
235 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
john h
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
