A answer u stated would be received in minutes? Try 30 mins now!!! Nothing
Posted by Rob collette on
1 Related Answer
Anonymous
  • 837 Answers
SOURCE: Hitachi 60EX38B shuts down after 30 min or 45 min of viewing.
I would offer that you at least take the back off and give it a good cleaning - compressed air etc .. its gotta be dusty .. the dust could be causing some heat problems
Posted on Mar 08, 2009
I want to type degrees minutes and senconds on the calc. to get the answer instead of typing in the answer to get it in DMS ... HOW DO I DO THATTT!ASAP!
You should have stated your calculator model. here's how I do it with my Casio FX-100D
This is how I divide 45° by 2 ----------------------------------------
Enter Degree mode [ --> 4]
45 2
Answer will be 22.5
Now press the button [° ´ ´´]
It will give the answer as 22° 30´ 0´´
This is how I enter 10° 20´ 30´´ --------------------------------------------
10 20 30
10.3416666.. will be Displayed.
To see it in Degrees, Minutes and Seconds
Press --> [° ´ ´´]
Answer will be shown as 10° 20´ 30´´
Sep 06, 2011 | Cameras
We will be watching the tv or any other audio or video source and the receiver makes a "pop" and the audio goes out. If we are watching TV the picture stays on till I turn off the amp to reboot...
Sorry to say it, but you just need to get a new receiver. There is probably a capacitor going bad on the circuit board. It's only a matter of time before it quits completely. The only other option is to take it to a repair shop where it can be tested. Hope this helps.
Mar 19, 2011 | Audio Players & Recorders
SPLIT AC NOT COOLING AFTER 30 MINUTES
sounds like the out door fan is not running and the comp is over heating, rec to start unit and check to see if the fan is running in the first 30-45 min, if not check cap or replace fan motor.
Jul 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Will not play or record, states on screen its in safeguard mode E03
try reseting the camcorder. most electronics go into safe mode when they detect a major problem so nothing else can go wrong. there should be a small pin hole some where that says reset or take out battery for 30 min. if this dose not work then take it somewhere to have it looked at.
Jan 02, 2010 | JVC GR-D290 Mini DV Digital Camcorder
My maestro 4050 stopped receiving a signal from the satelite
try the hard reset, set it out to the open sky for a few minutes (may take as much as 30 min) to acquire the sats
Jul 01, 2009 | Magellan Maestro 4050 GPS
Problems booting up. it cycles for up to 30 mins
Dear cobbsl00,
Whenever a system takes up to 30 minutes to boot, you may have a problem with the boot loader files, the Master Boot Record or the NT load files. If you are able to boot, immediately try to salvage any important data before it gets lost for good. Then try reloading your OS from scratch,
Jul 28, 2008 | ASUS Computers & Internet
I received my Acer 4315-2004 in December of 2007, and this week was the first time I travelled with it using the battery pac. Although the icon at the bottom right said it was 100% charged the screen...
Depends on the settings in the control panel/ power options.
If everything is maxed out 45 min to an hour is it.
If you tweak it you can get up to 2 hours if it is the heavy duty 4000-4400.
Apr 19, 2008 | Computers & Internet
Reciever malfunctions after 30 mins use
This receiver runs VERY hot during normal operation. Make sure you provide good ventilation for it.
With summer here, you might consider a small clip-on fan and clip it near the top of the receiver. The amplifier section is along the front of the chassis - so that's the source of heat.
See if unblocking it helps - then try the fan.
Aug 29, 2007 | Onkyo TX-SR304 Receiver
21 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
