Question about Motorola Televison & Video
Motorola cable box dcx700 system setup code - Motorola Televison & Video
Posted by Michael Galnares on
  • Michael Galnares
    Michael Galnares Jul 15, 2019
    I need to change resolution !!
5 Related Answers
dscollard
SOURCE: Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected]
Posted on Jun 15, 2008
Anonymous
SOURCE: Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Posted on Sep 08, 2008
DemonNeno
SOURCE: samsung code for a comcast cable box
The Remote w/ On Demand buttons, it's the same as the DVD player code 1932. Hit the AUX button, press and hold SETUP until AUX blinks and enter 1932. Press the power button and it should turn off the reciever.
*UNLOCKING VOLUME CONTROL* You must until your AUX volume control in order to use your Comcast remote. To do so, you must select AUX, press and hold SETUP until AUX blinks. Enter 9-9-3 and press Vol - (down). This should unlock your volume control when you select AUX. I'm not sure how to set AUX as your default setting for volume, unless you were to program your AUX device as your TV and vice versa I'd suspect.
Hope this helps!
Posted on Oct 04, 2008
Anonymous
SOURCE: Emerson Jumbo Remote Code for Motorola Cable Box Needed!!!
I just used 051 with the giant emerson remote and a motorola cable box. It worked right away. Good luck.
Posted on Dec 28, 2008
Anonymous
  • 2335 Answers
SOURCE: need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Posted on Nov 22, 2009
Issue programing Motorola Remote VIP2262 with Sony Bravia Home Theater System BDV-N890W/N990W
Motorola remote control have no setup codes to Sony Bravia HTS. If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
I need the remote code for Cisco cable box, model 9865HDC
This may not be a definite answer, but it may provide a hint what codes to try. Although the standard Cox cable box code for my Philips universal remote, 4200, worked for the 9865HDC, the standard code for my GE 24959, 0529, did not. Since Cisco acquired the Motorola cable box division a few years ago I tried all of those codes, but none worked. Then I noticed a single code 0506 for DVR under Motorola. It worked like a charm, even the dedicated DVR List button on the GE 24959. Hopefully you can find a Motorola DVR code for your universal remote.
I have Uniden DCX700 phone- how do I turn the ringer on and off?
The DCX700 is an expansion handset for several different Uniden phones (DCT746, DCT748). To change the volume of the ringer, press the Vol + or Vol - button with the unit in Standby (not making calls). There are three ringer volumes: Off, Low and High. Pressing the Volume buttons will let you cycle through the list. The volume buttons are to the left of Talk below the LCD screen.
You can temporarily mute the ringer by pressing Mute while the phone is ringing.
The manual for the DCT746 is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT746Mom.pdf . All Uniden cordless phone manuals are available in numerical and alphabetical order here: http://www.uniden.com/scat/cordlessphones_mnl . The manual for the DCX700 handset (with registration information) is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCX700om.pdf .
I hope this helps.
1helpful
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
1helpful
Cannot find a device code for ATT Uverse DVR cable box
SOrry for your plight, the Bose staff are correct, they do release occassional firmware updates via a DVD or a CD throught their costumers mailer. If you are not part of this mailer, you may go to any Bose service center and request the latest update disc for your Lifestyle 18-II system. Udpates should be able to help you sort out your problem.
Glad to be of service...
Need code for motorola cable box with a insignia remote
Assuming you have the DRC800 remote:
Codes are 0467 or 1376
You can EASILY program the remote without a key code:
1. Press the "cbl" button
2. Press and hold "setup" button Until red light blinks twice
3. Press 9-9-1
4. Press power button
5. Press chanel up repeadedly until your cable box shuts off
6. Press "setup" button again
That should be all there is to it. You can do the same thing for TV,VCR/DVD,Audio, whatever
It's easier than it looks.
Here is a website with more info if you need it:
http://www.eastlink.ca/cable/support/documents/DRC800_User_Guide.pdf
Samsung code for a comcast cable box
Hope this helps!
40helpful
6answers
2answers
Gain control of my Motorola cable box with a Sony RM-Y167 remote
Cable Converters (Set Top Boxes)
Director 0476
General Instrument 0476
Jerrold 0476
Motorola 0476, 1376
Pioneer 1877
Scientific Atlanta 1877
HOPE THIS WILL HELP YOU!!
18helpful
3answers
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
