Question about Akai PT4298HD Rear Projection Television
Curved red image on 46" Akai rear projection TV
I have an Akai 46 inch rear projection TV. The red images is curved up at the top sides and curved down at the bottom sides. I have tried using the convergence to adjust the red and blue colors. The red cannot be adjusted on the sides. I can get the center squares to align, but not the sides at all. When I move to the blue, the squares are all green and no adjustment can make the blue even show up. When I go to perfect focus, it goes through the process, but does not improve the red color.Any ideas?
Posted by nynyx3 on
dennis bullard
    Brigadier General:
  • 4,090 Answers
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Posted on Aug 29, 2009
Our tv is showing shadows behind images and a curved red line at the top, what could this be?
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Samsung PCL5415RB 54" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Red and green wavy lines
If the distortion that you see can be described as somewhat of a 3-D picture, the problem is teh convergence circuit and this can be fixed easily. Also, if you can solder, you can fix this yourself. If you wish to do this, please update this and I'll provide you with some instructions.
Dan
Sep 12, 2008 | Akai PT5492S 54" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Curved picture and double images
I had noticed your question before posting mine, since it appears no one had given you a solution thought i would share the solution given to me. Two different techs told me the same thing it would need a new convergence board. I ordered my board today hopefully have fixed soon as it arrives. I noticed your question has been hear awhile but thought maybe if you still needed some help I would share. It is going to save me $300 doing it myself, but if you are going to try make sure to talk to one of the techs first on live chat. Goodluck
Sep 02, 2006 | Samsung PCN5425R 54" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
246 people viewed this question
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
