SOURCE: Zanussi 1245w fails to spin
suspect it may not be rotating on wash either. check the moor brushes
SOURCE: Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
SOURCE: Zanussi FS1155W won't start
found out its the printed circuit board has burnt out behind the front panel two tracks on the panel leading to a green capacitor on the circuit board overheated so i resolded the tracks put the washing machine back together and so far its done several washes [touch wood its a sucess] the circuit board brand new from zanussi 135.00 pounds [so new washing machine if it fails] so hopefully theres a solution
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
