I don't find call timer for my mobile nokia 6300
To see the in call timer do the following while the call is active :
Menu -> Log (Call Register) -> Call Duration
You will see the top entry is Active Call, thats your in call timer.
If you cannot see Menu while the call is active you may need to use Clear (right Navikey) to clear away any numbers you have entered after starting the call.
If you go to settings it shoulds be there if not try call log
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
