Question about Husqvarna Sewing Machines
I have an old Husqvarna sewing machine model 1020 which dates to around late 1960s. I need to discover which brand of walking presser foot I can use on this model so I can do quilting.
Please help!!! I don't want to ditch this gem of a machine, but am finding it impossible to identify which generic type of walking foot I can use. It's driving me nuts, actually! I'm totally against planned obsolescence and the thought I must buy a new machine just for this purpose really worries me. I don't have the money for one, to put it simply, but I have lots of fabrics I wanted to sew to make some money. HELP!!! From Australia. Maybe they will know in Sweden...HELP!!!
Posted by Deborah Curtis on
Ruth summersides
    Genius:
  • Husqvarna Master
  • 1,477 Answers
Go line and type it in or go to eBay and type in the piece you need. They come in different shank sizes but are very reasonably priced so you could get a couple until one that fits your machine. You can always gift the ones you don't need. :-)
Posted on Jul 17, 2019
5 Related Answers
Anonymous
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
Posted on Jul 24, 2008
wfservices
Wayne Fellows
  • 262 Answers
SOURCE: Need instructions for putting a walking foot together
http://www.husqvarnaviking.com/us/2821_3079.htm
This is a link to husqvarna site for help..Hope this can help you. Wayne
Posted on Mar 21, 2010
paj42
  • 1116 Answers
SOURCE: I have a singer 6202 sewing machine and I need to
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
Posted on May 22, 2010
RichSew
Douglas Plant
  • 222 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: I have this White model
to allow the free moving and to do it by hand ..it has a button that will low the feeding dog and practically you will move the fabric by hand..or ..just remove the presser foot from the screw..or if it is possible ..free the screw and lift the foot up to the max..for a larger feeding dimension ..
Posted on Sep 01, 2010
Do I need a walking foot to stitch in the ditch using Viking freesia 415?
A walking foot would be helpful especially for quilting where there are multiple layers of fabric. The walking foot actually moves the upper layer in conjunction with the lower fabric helping to prevent wrinkles in the stitching.
For other projects, there may be other feet that could work. Your sewing machine may have other accessories, like this foot for Berninas Blindstitch foot 5
stitch in ditch Google Search
FWIW, it is very difficult to actually stitch "in the ditch" as any slight deviation will show. Usually, it is better to stitch just a bit to one side or the other.
Dec 10, 2017 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Install a walking foot
Please see previous answer on walking Foot installation, it will be similar for your White
as many machines, the walking foot is after market generic design
http://www.fixya.com/support/t1177947-elna_walking_foot
Mar 09, 2015 | White Sewing Sewing Machines
How do I stitch in the ditch for 103 a straight line of 103 inches without wavering.
I draw a line on the fabric with a sharpened bar of soap. then hold the fabric as far away from the needle as you can. It will help you stay straight.
Dec 17, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
I am trying to adjust the timing on the feed components on a brother single needle walking foot sewing machine it wrinkles the bottom layer when it,s sewes
So let me translate that to make sure I (and others) understand your gibberish.
You have an industrial Brother with a walking foot. When sewing the bottom material is puckered and you want to know how to adjust the feed.
First, puckering on the bottom is often a tension problem. So double check the threading and bobbin. Make sure the bobbin is unwinding in the correct direction. ALWAYS START WITH THE SIMPLEST SOLUTION FIRST THEN MOVE ON TO THE NEXT SUGGESTION.
here is a link to an industrial trouble shooting guide that will help you identify the cause of the puckering.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEwQFjAD&url=http%3A%2F%2Fwww.amann.com%2Fdownload%2Findustrie-naehgarne.html%3Ftx_abdownloads_pi1%255Baction%255D%3Dgetviewclickeddownload%26tx_abdownloads_pi1%255Buid%255D%3D265%26no_cache%3D1&ei=LdrLUI3XLcfhiwKHjYGoBg&usg=AFQjCNHkD8souq5yFjQU6FipSR3jddkk1Q&bvm=bv.1355325884,d.cGE
In the mean time can you please give us the Model number of your Brother?
Dec 14, 2012 | Sewing Machines
Does the Stitch in the Ditch foot have slot for the needle, the one have has a central hole, I need to be able to move the needle positinn slightly to the right. many thanks. Yvonne Kneubuhler ...
I always stitch in the ditch with my regular clear plastic pressure foot so I can see where I am stitching and keep the stitches falling into the seam gap (the ditch).
Sewingpartsonline.com have a "stitch in the Ditch" foot and it looks like it has a wide slot. It seems to have a nice metal rudder to line up in the seam line and that looks central so you'd still be stitching right in the middle of the foot I'd say if you used this one.
link is http://www.sewingpartsonline.com/stitch-in-ditch-foot-low-shank-p60706.aspx
But you'd need to get the correct foot for your machine, that one is a low shank so it may well fit if your machine is a low shank type.
Sep 21, 2011 | Sewing Machines
Have brother sewing machine sc9500. Need invisible zipper foot. Don't know which kind to get.
My invisible zipper foot is a plastic generic one which was describd as being "low shank" and it works fine on three different Elnas I own.
I would have thought your machine was a low shank style too, there is a fair bit of similarity between feet with low shank clip on style. So if your feet clip on and off the shank, then you should be able to clip on another type of foot too.
if you try this link http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
then go through to the page for the foot attachment system that looks like yours you might be able to establish which one you need. THere is a brother high shank invisble foot listed, and an alternative part number. I jcan't see a Brother SC9500 machine listed so you might need to do a bit of elimination.
You could also email sewingpartsonline.com and ask them to help you identify the right foot.
Jul 12, 2011 | Brother Sewing Machines
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
