Question about Mitsubishi Heating & Cooling
Black particles coming out of my Mitsubishi ductless air conditioner
Posted by Richard Buskey on
Tim Miller
    New Friend:
  • 29 Answers
It is, more than likely, that it is not coming from your unit. Is someone burning candles? If they are, please stop burning them and use a candle warmer instead. The burning flame of most of the candles today, produce a lot of very unhealthy pollution in the soot that they produce, not to mention the health aspects to you. Scented candles are the worst. The unit usually gets blamed for picking this up and redistributing the particles back into the air.
Posted on Sep 23, 2019
5 Related Answers
Anonymous
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
Anonymous
  • 400 Answers
SOURCE: lg ductless air conditioner is coming up with code ch 5
Communication between indoor PC and outdoor PC missed. Check that all connecting cables are good.
Posted on May 08, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Posted on Jul 30, 2009
hmlee390
  • 736 Answers
SOURCE: how to pump down a ductless air conditioner split unit to remove
if the unit contains R12 or R22 you are not permitted by law to do the work yoiurself .. you have to have a "certified" person to reclaim the freon ... you might be able to get away with removing R134A (check local law) if thats what it has ... there is a service port that you can hook gages/hoses/vacuum pump up to .. (if not, then one must be added, usually in the form of a saddle valve that penetrates a low side feed pipe ... you should vent it into an approved tank or bladder (like a big balloon) for disposal or reclamation .. there may be a community service in your area that comes out and reclaims freon from old refrigerators and such .. in my area there is a free service that will reclaim the refrigerant and take away the old equipment .. i think its free or low cost .. some people simply vent R134 to atmosphere but that is polluting and may violate some laws .. R134 was thought to pose little hazzard but that is being reconsidered now in many countries
you can become certified yourself by attending a class and taking an exam that shows you understand the dangers and are aware of the law ..
Posted on Aug 20, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
Ice hitting outside fan
It sounds like your system might be low on coolant. Check the pressure of the main line and check it against the specs. You may have a leak in the system.
Mar 02, 2015 | Rheem 12,000 BTU Mitsubishi 13 SEER R-410A...
Unclog a/c drain on mitsubishi ductless mr. slim
you should have a drain on the outside of the house take a shop vac and suck this drain line out, Make sure your filter is clean.
Jul 15, 2014 | Mitsubishi MS-A12WA & MU-A12WA Mr. Slim...
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
What is the manufacterers warranty on the SRK40HG-S AIR CON UNIT?
Those ductless systems come from Mitsubishi with a 3 year parts warranty
Mar 24, 2010 | Mitsubishi Heating & Cooling
Ductless heat pump - how many and where located in home
i live in sandwich and am mitsubishi expert
please call
508-420-3922
yellowdog services
to much to type here
Sep 26, 2009 | GE Quiet-Aire Ductless Heat Pump Split...
Mini split AC's
they are excellent and very efficient sytems
i have a muti pass ductless in my home and swear by it so much i went to school for them
I am now a mitsubishi cert expert
and cannot sing the praisees high enouhg for the ductless systems
Jun 14, 2008 | GE Quiet-Aire Ductless Mini Split System...
Ductless heat pump systems
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Nov 15, 2007 | Mitsubishi MSH12TN Air Conditioner
Heating & Cooling Logo
242 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
NOEL
NOEL
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
