Question about Coby Radio Communications
My Coby CEBT-405 bluetooth headset won’t work. It just blinks red the entire time when I try to charge it, and otherwise doesn’t respond to any sort of button press. I think I’ve been scammed but hopefully I’m wrong?
Posted by PrinceNahari on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Blinking yellow power led
check at the back of the tower you would find 4 LEDs(small lights) labeled ABCD in a row or you might have 1234 on the front panel. note the status of these LEDs when the problem occurs and check for the solution accordingly on the support.dell. website.
would also suggest to disconnect all the devices (keyboard mouse printers etc.)next time the problem occurs and then try to start the computer
Posted on Jun 02, 2008
Anonymous
SOURCE: bluetooth headset won't connect in Vista
I had a similar problem. First part of the solution is to disable the headset profile for the headphones. These headphones can't handle both headset and headphone profiles at the same time. Second part of the solution is to make sure that your headphones are on when you activate bluetooth on the computer. For some reason, Vista doesn't like setting up the initial connection on-the-go, so it will just act like its connected and move on. Hope this helps!
Posted on Mar 22, 2009
Anonymous
SOURCE: Blinking lights no response
I was able to fix this same problem by doing a hard reset, and re-synching with my computer.
To do a hard reset, press the power button and the two center buttons, all at the same time. Hold them down for about 10 seconds - when you let go, the tablet will start trying to synch again. Once you go through the synching steps again, everything should work properly.
Posted on Apr 14, 2009
Anonymous
SOURCE: Samsung WEP150MBE not working
whats the answer i have the same problem
Posted on Nov 19, 2009
ikebert
ikebert
  • 47 Answers
SOURCE: The headset keeps blinking a red light
I had this very same issue which was remedied when I unplugged the headset recharging dock for approximately 5 seconds then plugged it back in. After about 10 seconds everything re-synced and was fine after that. -No more blinking.
Posted on May 11, 2011
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
BLINKING RED LIGHT WHEN TRYING TO CHARGE UNIT
I fixed this problem by connect it on the charger,hold +and - keys together for 10 seconds,it started to charge and work well.
Jan 21, 2014 | Motorola Mobility H730 Bluetooth Headset
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
My plantronics voyager pro wont turn on, It doesn't fill power on-off bottom. I can only charge it correctly with red led. Each time when I press "volume+" bottom for 5 seconds while charging...
Sounds like you have a few things going on here that may be a procedural problem. We recommend reviewing your user guide, paying close attention to the "take a good look" and "tips". The link below for the Plantronics Voyager Pro+ should help.
Good luck from Headsets Direct!
Oct 13, 2011 | Plantronics Voyager PRO Bluetooth Headset
Blinking red while charging? will not turn on when unpluged
On the back of the headset you'll locate the power button. Turn off your headset before charging. It should glow red while it's charging. If it still doesn't come on, it's time to see your retailer about getting it replaced or call Plantronics at 800-544-4460 x5 x5538 for service.
Jul 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
Hello, I just bought Nokia BH 504. Just after I bought it, I tried to switch it on and create connection with my mobile phone (Nokia XpressMusic 5530). The green light was blinking, bluetooth in my mobile...
I am not going to solve anything. I have an even worse problem. The headset will not start at all. The red light is on when you charge it but the multifunction button does not respond. I had the headset paired previously with ipod touch 3g. im not sure it's apple or nokia but I feel I was ripped off in London when I bought the headset.
Nov 19, 2010 | Nokia Bluetooth Headset BH504 Schw
Not working, not charging
Try to juggle the charging port, if it blinks again, then you have a broken charging cord
Jul 30, 2009 | Sennheiser VMX100 Bluetooth Headset...
Bluetooth ear piece
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
Jul 15, 2007 | Sony Ericsson Akono HBH-608 Wireless...
Radio Communications Logo
212 people viewed this question
Top Coby Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Coby Radio Communication Expert? Answer questions, earn points and help others
