Question about Acer TravelMate 2300 Notebook
How to use keys in acer travelmate 4730
How to use the extra keys on the upper side of the keyboard of acer travelmate 4730
Posted by nikunjsatra9 on
Anonymous
    Sniper:
  • 76 Answers
Press and hold the "Fn" key and press one of the alternate keys.
Posted on Aug 29, 2009
How i can disable pxe rom in acer travelmate 4730 bios set up?
Are you comfortable with playing around in the BIOS? You should find it under the boot sequence options. BIOSes tend to be a little different from machine to machine so I cant really point you in a specific direction. Maybe someone else has more familiarity with this model.
Sep 21, 2014 | Acer Travelmate 4730 Notebook
Extra
exactly the same but you can dismantle the motherboard for faster result
Mar 25, 2014 | Acer TravelMate Computers & Internet
Using the Fn key with the relevant function keys on my Acer TravelMate 2480 Notebook does not work. The combination of Fn and F5 function key, for instance, should send data to a projector or a secondary...
That's because you activated the NumLock mode!
Have a look at your keyboard -upper right-, you'll find a "NumLock" key, push it once more and you will deactivate it and retrieve the normal use of any keys!
Good luck, Jopica123
May 17, 2011 | Acer TravelMate 2480 PC Notebook
Acer Travelmate 4730 takes ages to load windows, VERY SLOW
in control panel ,,do a disk cleanup and defragment ur hdd,
Nov 03, 2010 | Acer Travelmate 4730 Notebook
Behind the screen,there is some dust
I didn't find guide exactly for you PC but I found for other two. However, the method would be the same, disassemble carefully and clean. there you go 2 sollutions:
http://kenkinder.com/literally-debugging-a-laptop/
http://www.fonerbooks.com/laptop_6.htm
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Acer Travelmate 4730 Notebook
The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Sep 04, 2009 | MSI M510C Notebook
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Keyboard Laptop ACER 2304WLMi the e key has come off -
No, there arn't any tricks for keeping your keyboard free from dust,coffee spills,crumbs,etc.
Extra caution is always a good remedy.
If you have prob. with keyboard,blow out with compressed air can.Buy from computer shop.
Also turn laptop over & tap lightly to dislodge any foreign material that may be wedged between keys & pad.
Feb 01, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
153 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
