Question about Ovens
Bosch range outter glass shattered
The glass on the door shattered. I need to replace it, but am not sure what I need. I haven't had much luck as far as finding many others with this particular model, and don't know how much size varies from model to model. I need some advice installation wise as well. Anything would help, Thanks. Bosch Range HES242U /01
Lollo Pop
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
You just need the glass, get part number from Bosch website (UK) and source locally.
To fit just dismantle the door.
Posted on Aug 29, 2009
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
The glass has shattered in my electrolux eou6330x door
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
Glass oven door shattered
We must have a model number to answer your question.
Dec 26, 2009 | Ovens
Inner glass on bosch HBC84k550b microwave shattered following arcing - have ordered replacement but need instructions on fitting it correctly
Strangely enough I had exactly the same problem but today managed to fit the new inner glass and door panels without any problems, here is how.
YOU NEED 2 PEOPLE FOR THIS STEP. Open the door, at the top are 2 large plastics flat head screws, undo these making sure your helper is holding the door securely or itll fall on the floor, te door will unhook once the screws are fully undone
Once off you can close the microwave back up.
Now there are two screws, one in each top corner holding a funny looking plastic wing shape that slides into the inner door. They have a star screw head. Undo both of these and remove the plastic wings. When you remove these the panel underneath will try to fall off so be prepared to catch it, along with the plastic screws undone in step 1. This now unhooks like the main door did.
From here you'll be able to see the back of the inner glass. This is held in by a mesh at the back and about 15 screws, star headed again. you can simply remove all of these, that will release the front panel over the inner glass, again, you might want someone to hold the door open so the panel does not drop when you remove the last screws.
Thats it as far as taking the microwave apart. put your new glass in, remembering to make sure the rubber seal is put back between the glass and inner door.
Simply reverse the process.
It took me approximately 1 hour and I am by no means a DIY person.
Good Luck
Mike
Dec 15, 2009 | Bosch Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Inner glass door lower double ove
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
Mar 23, 2008 | Bosch HBN 455 Stainless Steel Electric...
Ovens Logo
204 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
