Question about Beko Washing Machines
I have a beko washing machine wmd 78127 with flashing degree symbol after temperature and after some timeit goes to pause cant start
Posted by Godfrey g on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Posted on Jan 09, 2010
samesymptom
SOURCE: beko wm6152w turn machine on
try holding the start/pause button in for five seconds, hopefully it will restart
Posted on Aug 29, 2010
john_cross
  • 6277 Answers
SOURCE: BEKO wma 250s washing machine does
This sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
john_cross
  • 6277 Answers
SOURCE: beko wm 5140 washing machine is starting its cycle
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Aug 10, 2011
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
Washing Machines Logo
Top Beko Washing Machines Experts
Marvin
Marvin
NOEL
NOEL
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
