MY DECODER IS NOT PICKING UP SIGNAL. THE MESSAGE SAY CAN NOT PICK UP SIGNAL AUTOMATICALLY WHAT CAN I DO? I HAVE CHECKED ALL THE CONNRCTIONS AND ALL SEEMS FINE.
Posted by Alice Naidoo on
2 Related Answers
Anonymous
  • 80 Answers
SOURCE: lg phone will not pick up signal from verizon
Try hitting menu 0 or ##77647268300 and send one of these should get you into a programming menu(depends on the software version) service code is '000000' and you are going to check option under Network and band preference, should be set to 'Any' not 'cell only'
Posted on Jul 11, 2010
vinceisaac
francoise cleofas
  • 2432 Answers
SOURCE: my alba tv had stoped picking up the signal
if your tv has only a raster display or just like a snow white raster appear with any channel receive, the cause is failure in the tuner board. the problem either has a loose connection inside of the tuner or no supply .if you have the tools like the philip screwdriver and soldering iron you can do this . remove the cover to access the internal part of the tv then look for the tuner, the tuner board this is where your areal antenna hooked up covered with metal. remove the metal cover then check weather the connection going to the RF coaxial of the tuner get broken or loose contact, just re soldered the connection.if still no channel receive, at this time you will need to have voltage checking which provide a digital tester. if you don't have an idea about this at this time you need a help with a trained tv technician.
Posted on Nov 06, 2012
What does NO SIGNAL mean on fios tv screen?
It means that whatever your input is supposed to be, the TV is not picking up anything.
If your input, say a TV aerial or satellite decoder is connected to the ANT socket of your TV, then either the RF coax cable or the device producing the signal is off or disconnected.
The same goes for any other inputs that the TV is currently set up to receive.
Check your menu to see what the input is set to such as TV, AV then check that connection is good.
Nov 13, 2017 | Televison & Video
How do I fix the irritating shhhshshsh sound on my Hisense TV
Try moving the decoder to the other side of the TV, or farther away. The TV audio circuit may be picking up electromagnetic noise from the digital circuitry in the decoder. Another possibility is a defective audio circuit in the decoder.
If you are connecting the decoder to the antenna input on the TV, the problem may be a misaligned (mistuned) audio modulator output in the decoder. In that case, if you have the option of using a different TV channel on both units, try that.
Sep 21, 2014 | Hisense TC14FS68 TV
My clock quit picking up the atomic signal, even with new batteries installed.
Try temporarily locating it in a different location until it picks up a signal, usually around a window.
Mar 01, 2013 | SkyScan 86709 Atomic Wall Clock
My alba tv had stoped picking up the signal
Nov 05, 2012 | Televison & Video
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Can't pick up signal on the other room for my dstv
chances are your problems lie with your connections themselves, most cases its with the splitter box if you are using one, if u are then rather remove the splitter box altogether, u will then need a set of RCA cables (the red white and yellow cables that come with DVD players) use these to connect the first point directly from the decoder to the TV using a free AV input behind the TV. form then on proceed to connect the cable going to the room directly to the RF OUT port behind the decoder (make sure the copper and aluminium wires dont end up touching, but use both, the copper on the inside and the alu on the steel outer casing) if this doesnt work check your connections and if all fails replace the cable as a last resort
Oct 08, 2009 | LG DR787T DVD Recorder
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
