Dell Latitude D600 Sprint Pantech Internet card -When I insert my internet card into the PCMCIA port one of two things happens. 1) The computer freezes up. Screen stays on but the keyboard, mouse pad are disabled. Once the card is ejected, everything is unlocked again. 2) Sprint Connection Manager does not even recognize card. The flashing light on the card does not blink. I have uninstalled the software and reinstalled. No luck The card works on other laptops (D600's) perfectly fine. I did try replacing the PCMCIA port with another and the same problem occured. I have ran a virus/malware scan and everything checked out. Any ideas?
change the lan cable then check
orremove the lan cable start the laptop then go to the device manager remove the driver shut it down , reboot it install the driver then check,
Yes call Fries Electronics let them know what model laptop you have they can tell you the type of memory you need SoDimm more then likely, they will give you a price. It is better to remove the old memory and take it with you when you go to buy it has to match. Also you can ask what is the largest recommended hard drive they have for this model laptop, probably 60gb. The motherboard for that laptop does have limitations. That laptop probably does not have a built in wireless card so you can either use a hard wire RJ45 Data cable and plug the other end into your Internet Router, or you can purchase a PCMCIA Wireless Card to insert into the slot on the side of the laptop. This PCMCIA Card will allow you to access the internet wirelessly. You have now beefed up your CPx Latitude.
There are several types of wireless modems available.
A PCMCIA wireless card that inserts into the laptop's PCMCIA slot.
A stand alone wireless modem that connects into the LAN port (10BaseT connector) with a network cable or a USB cable to the computer's USB port.
and
A USB wireless device (similar in size as a USB memory stick)that connects into the computer's USB port.
im not sure with your computer but my computer did the same thing but later after looking at my computer i realised it had a switch for wireless and it had accidently bin set to the off postion
You can try setting up a new internet connection through the internet connection wizard, but you will probably need a disc from Sprint in order to do this.
