Question about Royal 1280MX Shredder
Shredder problem Green light turns red and does not run. Mail had a coin in it. Similiar to Larry's problem.
Posted by firstmatep29 on
Anonymous
  • 328 Answers
You obviously have to take it apart to remove the coin. Remove the four screws from the top cover and carefully lift it up, making sure not to damage the circuit strip connectec to the board.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
Have a Philips teleprojecter 51pw9303 and just recently the red green convergence went all wacky on the upper left corner and all across the bottom. Itryed to reallign manually but with no success, what...
yes it can be fixed very easy The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 14, 2010 | Philips 51PP9303H Rear Projection...
Green dot
Larry Dillon.
May 10, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Problems whith my philips 55pp9363/17
no do not try to adjust the green convergenceonly adjust the red and blue into the green if the red or blue will not move most likely you have bad convergence ic's. The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
Larry Dillon.
May 04, 2010 | Televison & Video
Rca hdtv black screen at top picture at bottom
if you are talking about the picture looking like a 3-d picture, The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
Larry Dillon.
May 04, 2010 | RCA HD52W56 52" Rear Projection HDTV
Replaced batteries, fires once, red light stays on. Turn off, restart, same pattern.
Hi Larry,
Change all four batteries, I think one or more were not 1.25 or more voltages.
[email protected]
Jan 11, 2010 | Vivitar 285HV Flash
No picture on tv.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point, is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Sony Televison & Video
Where can i get a wiring diagram on how to install my valet remote car starter in my 1999 Dodge Durango i can't seem to find the wires i need to hook them up to the romote starter
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS Ignition 12 volts D BLUE IGNITION SWITCH HARNESS Starter YELLOW IGNITION SWITCH HARNESS Dome Light YELLOW (-) AT COURTESY LIGHT UNDER DASH ** Trunk Pin TAN/BLACK (-) AT SWITCH OR CENTRAL TIMER MODULE * Parking Lamp BLACK/YELLOW (+) AT HEADLIGHT SWITCH Lock ORANGE/VIOLET 10 PIN CONN. IN DR #203 Unlock PINK/VIOLET KICK OR CTM * Tach Signal BLACK/GRAY AT IGNITION COIL OR PCM * tab_rs.gif Ignition #2 BLACK/ORANGE IGNITION SWITCH HARNESS Ignition #3 D GREEN/RED ** IGNITION SWITCH HARNESS Accessory BLACK/WHITE IGNITION SWITCH HARNESS Neutral Safety BLACK/WHITE (-) AT SWITCH ON TRANSMISSION OR PCM * Brake Light WHITE/TAN (+) AT SWITCH ABOVE BRAKE PEDEL Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION Rear Defrost N/A TIMER BUILT INTO SWITCH
Hope this helps
Jan 26, 2009 | Directed Dei Valet 561r Remote...
I just bought and installed a Frigidaire Affinity four prong heating cord and when I turn the power on through the fuse box, the dryer lights up, allows me to select the drying options but does not have...
you should have 4 wires / red, white, black and green / red and black goes to the outside temmals and white to middle and green to cabinet / check and see if you have it connected that way / larry
Dec 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Green flashing light and tv will not turn on
that is usually repaired by replacing the DM capacitors. You can get the V21/ V19 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures on cd so you can easoally do the repair yourself. Heres the link its listed under the repair kit category as the V21/V19 DM repair Kit.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Royal 1280 MX green light turns red, does not run
The 1280mx has a circuit that detects the high current when the motor is jammed. The 5 watt, 0.5 ohm resistor/fuse (marked as R1) that is part of this circuit blew on my unit. No visible signs of failure, you have to remove it from the circuit board to test it. When R1 fails more current than normal passes through the R2-1k ohm resistor; need to check if it also failed.
Nov 25, 2007 | Royal 1280MX Shredder
Royal 1280MX Shredder Logo
148 people viewed this question
Top Royal Office Equipment & Supplies Experts
Marvin
Marvin
Ed
Ed
Sheldon Dedek
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
